Vacuum Sensor/line hook up help.
04-17-2008, 09:00 AM
So many questions... so little time :))
Quote:I also have a pic I will attach of three sensors? Do they need to go on?The solenoid valve on the LEFT is typical of the type of valve used by the "idle-up computer". Connected between a clean air tapping on the engine air intake and one of the small tubes (that you have looped) on top of the throttle body. It operates to compensate for additional electrical load, such as rear screen heater, brake lights etc. The metal covered object in the CENTRE appears to be the injector solenoid aka injector ballast resistor. It should have three wires and a round plug. It connects between the 12V supply and the injectors to limit the current drawn by low impedence injectors. The solenoid valve on the RIGHT it typical of the type of valve used for the air conditioning idle-up circuit. No idea what triggers it, but I would guess it triggers from the A/C clutch circuit. The car will run OK without the idle-up valves, but if you have low impedence injectors (<6 Ohm) you MUST use the ballast resistor. Cheers... jondee86 |
| Messages In This Thread |
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
So many questions... so little time :)) - jondee86 - 04-17-2008 09:00 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
Don't loop the idle-up tubes.... - jondee86 - 04-20-2008, 09:03 AM
| map sensor cheating? | fdsjakl890 | 8 | 4,274 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 9,784 |
| fuel line hose from the pump | Wikizz | 4 | 8,640 |
| US-spec vacuum hard lines | LordTD | 2 | 7,144 |
04-27-2015 07:18 PM Last Post: Project D |
| AE86 Engine Coolant Temp Sensor | izanagi | 8 | 25,073 |
