Vacuum Sensor/line hook up help.
04-14-2008, 11:52 PM
Okay I thought I had it right but.. If I didnt mention Before I am Running both Pwr Steering and A/C both of which have came off a GTS But seem to fit fine. BUT my problem is now. I have confused my self as to how to hook up the vac lines for the Pwr steering and the AC I also have a pic I will attach of three sensors? Do they need to go on? And I think the one to the far right is the A/C Idle up sensor? The other two im not sure about..
[Image: AEU86 AE86 -  ]
Also can anyone help me buy telling or even showing me with a pic on how to hook it all up?.. Its racking my brain..Banging head
Also upon hooking up some of the harness I found a plug that I have no idea what it is I will attach a picture of that below. It seems to tie in just under the fuse box but I cant find any plug on the Japanese engine harness that will lug into it. Also nothing on my old harness?? Huh
Now Last But not least. ( I hope Crying ) I also see that just after a black square plug with one wire in it ( Black with Red Stripe ) has been cut... Where does it go? Its around the Igniter part of the harness..
PS. Does anyone know where the Wire/s for the A/C would be on the Japanese Harness? I think that Im going to have to splice in the US plug onto it to beable to use the US GTS A/C Pump...
THANK YOU ALL FOR YOUR HELP!! Respect! Crying
Messages In This Thread
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008, 09:34 AM
[] - Nanaki - 04-14-2008 11:52 PM
[] - Nanaki - 04-16-2008, 06:29 AM
[] - banpei - 04-16-2008, 04:20 PM
[] - parrot - 04-17-2008, 05:14 PM
[] - Nanaki - 04-17-2008, 09:22 PM
[] - Nanaki - 04-17-2008, 09:27 PM
[] - parrot - 04-18-2008, 01:20 AM
[] - Nanaki - 04-18-2008, 06:13 AM
[] - parrot - 04-18-2008, 06:28 AM
[] - F0Bman - 04-18-2008, 08:24 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
[] - parrot - 04-20-2008, 04:21 PM
Big Grin map sensor cheating? fdsjakl890 8 4,310 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,838 05-23-2022 10:00 PM
Last Post: The Doctor
  fuel line hose from the pump Wikizz 4 8,660 10-16-2017 07:11 PM
Last Post: jdm86gtz
  US-spec vacuum hard lines LordTD 2 7,166 04-27-2015 07:18 PM
Last Post: Project D
  AE86 Engine Coolant Temp Sensor izanagi 8 25,117 09-06-2014 05:47 PM
Last Post: izanagi
