Vacuum Sensor/line hook up help.
04-10-2008, 09:34 AM
Things you don't need....
Sounds about right. There will be two larger tubes under the throttle
body for the power steering idle-up, and possibly two for an air-con
idle-up. Main thing is to make sure you block off any tube that sucks
in air when the engine is running. Don't loop the idle-up tubes.
A tube that is not blocked off will act as an uncontrolled air leak, and
any air leaks into the manifold will push your idle speed up.
Don't know about the O2 sensor, but how far wrong can you go with
only one wire ?? Try it and see if it throws a fault.
Cheers... jondee86
Messages In This Thread
Vacuum Sensor/line hook up help. - Nanaki - 04-10-2008, 08:29 AM
Things you don't need.... - jondee86 - 04-10-2008 09:34 AM
[] - Nanaki - 04-14-2008, 11:52 PM
[] - Nanaki - 04-16-2008, 06:29 AM
[] - banpei - 04-16-2008, 04:20 PM
[] - parrot - 04-17-2008, 05:14 PM
[] - Nanaki - 04-17-2008, 09:22 PM
[] - Nanaki - 04-17-2008, 09:27 PM
[] - parrot - 04-18-2008, 01:20 AM
[] - Nanaki - 04-18-2008, 06:13 AM
[] - parrot - 04-18-2008, 06:28 AM
[] - F0Bman - 04-18-2008, 08:24 AM
Do you wash and wipe ?? - jondee86 - 04-20-2008, 08:50 AM
[] - parrot - 04-20-2008, 04:21 PM
Big Grin map sensor cheating? fdsjakl890 8 4,401 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,994 05-23-2022 10:00 PM
Last Post: The Doctor
  fuel line hose from the pump Wikizz 4 8,709 10-16-2017 07:11 PM
Last Post: jdm86gtz
  US-spec vacuum hard lines LordTD 2 7,230 04-27-2015 07:18 PM
Last Post: Project D
  AE86 Engine Coolant Temp Sensor izanagi 8 25,313 09-06-2014 05:47 PM
Last Post: izanagi
