VVt trigger on a silvertop.
06-24-2008, 10:11 PM
I am just about to fit a 20valve silvertop, I am running a standalone ecu, what way do I trigger the vvti? I know it has a connector for it on the head above the exhaust manifold..
Any info would be great. Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
06-24-2008, 11:38 PM
i think,12 volt and a massa(-) trigger from the ecu,just on and off i can check it on my blacktop tomorrow
06-24-2008, 11:43 PM
just from memory..
- never enabled with water temp < 60C - enable at 4000 rpm could be off a bit, but its based on both the temp and the rpm. |
06-26-2008, 01:09 AM
It has two wires from it from, I take it one is 12 volt supply and the other will activate when switched to ground. I can trigger from various things on the ECU, just wondering if there was any benefit from triggering early. Heard something about Honda V-tecs making more power with Vtec controllers and vtec switching early.
06-30-2008, 04:19 AM
I tried switching +12 and ground onto the solenoid, nothing happens, is this correct?
Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
07-01-2008, 12:58 PM
Got it sorted, It does use a 12v trigger, it was just stuck, removed it from the head and cleaned it. It should also measure 13 ohms.
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 8,061 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 18,043 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 7,180 |
| stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 7,508 |
| 20V VVT on standalone ECU | fax0815 | 5 | 12,441 |
08-09-2013 09:27 AM Last Post: rene |
![AEU86 AE86 - VVt trigger on a silvertop. [Image: AEU86 AE86 - VVt trigger on a silvertop.]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
