VSS signal from stock cluster ?
12-12-2011, 01:32 PM
Hi
Reading about electric P/S i came on info that there is a VSS signal on stock clusters that can be used as VSS pickup.
Original post is here:
http://hachiroku.net/forums/showpost.php...stcount=21
I'm curious, have anyone tried this ?
I could really use VSS on my standalone, and this way it seems (too) easy.
Thanks
12-12-2011, 02:07 PM
I didn't tried yet, but i think i will have to do it when i start the BT wiring...
Keeping the AE86 alive!
12-13-2011, 08:36 AM
Look here... http://www.autoshop101.com/forms/h36.pdf
At the bottom, reed switch type VSS. There is a four-pulse per revolution
output signal generated by the rotation of the speedo cable. I have tapped
it for use with an Apexi RSM meter on my AE86, and it works fine.
Cheers... jondee86
12-13-2011, 10:46 AM
Helpful as always, thanks Smile
Only unknown left is voltage.
With VEMS this is kind of scary.
VSS pin is connected directly to main CPU and anything above 5V can (and 12V will for certain) kill main CPU and cause serious damage to whole ECU.
12-13-2011, 11:43 AM
As far as I can see, the VSS switches an ECU output to ground in the
stock configuration.
Cheers... jondee86
12-13-2011, 11:46 AM
It's a ground signal vss. You need to run a pullup resistor.
EDIT: beat me to it! Wink
Andrew
12-13-2011, 01:42 PM
Thanks, both of you, will let you know how it works.
  EUDM gauge cluster banpei 22 12,102 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 2,800 06-23-2023 09:11 AM
Last Post: r.ave
  Digital speedometer on stock dashboard FanIsHere 0 2,938 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 4,862 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 17,599 07-18-2019 03:52 PM
