Using stock gauges with an engine conversion
10-03-2013, 02:15 PM
Is it possible to get the original rev meter and speedometer to work with a CA18DET engine and gearbox?
10-03-2013, 03:56 PM
Yes..
Needs a cable drive for the speedometer (I've seen an ae86 cable stuffed into a CA18 gearbox working), but without a different ratio gear it will show the wrong speed for sure.
Tachometer can be used with ECU signal with a tach signal booster.
10-03-2013, 05:42 PM
Ivan141 Wrote:Tachometer can be used with ECU signal with a tach signal booster.
I would recommend using the Omex one for this, it's inexpensive and easy enough to fit.
10-03-2013, 10:20 PM
Hi Jezza, do you have a link to the Omex part?
I've been looking at the speedometer, it seems I need to buy a mechanical speedo drive for my gearbox (which doesn't seem easy to find). I'll also need to buy a cable.
My diff is a 4.6 so i'll need to get a gear to match. It all seems like a pain but hopefully worth the effort
10-03-2013, 11:34 PM
You can also buy a part that lets you set the speed yourself+cable,but forgot the name.Will look it up.
10-04-2013, 01:10 AM
Escy Wrote:Hi Jezza, do you have a link to the Omex part?
I deal with omex, they dont show the converter on their page. I blive they retail at 25gbp +shipping to wherever you need it send to.
They ment to convert a + square signal to a - peak signal.
So if your Nissan Ecu got a digital output, as in square and +, the omex converter works very well!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
10-04-2013, 10:43 AM
Omex converter is 15 gbp.. look for Omex Tachometer driver, you'll find it in webshops. Emerald also sell a tach driver, but it's 35GBP IIRC.
You can make these converters yourself (I have built quite a few), but even I will no longer invest time and effort into something that can be bought for 15GBP. Thats a properly fair price and you get production quality too.
10-04-2013, 03:42 PM
If all else fails, you can send Omex an E-mail directly and inform them of what you need. [email protected] Thumbs up!
  20v Blacktop conversion.... Mylesmck 0 1,673 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 5,539 02-08-2024 10:30 AM
Last Post: r.ave
  Digital speedometer on stock dashboard FanIsHere 0 2,941 11-09-2022 01:36 PM
Last Post: FanIsHere
  AFM to Map Conversion ps13michi 3 5,893 01-06-2022 10:34 AM
Last Post: ps13michi
  82mm Stock compression Pistons apardal 4 4,871 11-24-2021 04:26 PM
Last Post: apardal
