Upgrade Brake Master Cylinder
04-26-2006, 11:47 AM
Getting stainless lines should help reduce the compliance in your hydraulic system.. it's not much, but it does help the brake response. You could also get a master cilinder brace. That stops the master cilinder from moving around and has a similar effect as stainless lines.
Making sure that everything around the calipers is in tiptop shape is also an important measure (slider pins should be straight and completely smooth + lubricated). I'm completely convinced by the mintex pads on my 360 that they should perform pretty well on an ae86 too. Last trackday I drove the damn volvo without rear brakes (badly worn out linings in the drumbrakes) and it still stopped without a problem all day long (be it a bit unstable). FABRICA MI DIEM, PVNC! |
| Messages In This Thread |
Upgrade Brake Master Cylinder - Rasteirinho - 04-07-2006, 11:32 AM
[] - jamiemirror - 04-07-2006, 02:09 PM
[] - jamiemirror - 04-07-2006, 02:23 PM
[] - Rasteirinho - 04-07-2006, 02:29 PM
[] - jamiemirror - 04-07-2006, 02:35 PM
[] - Rasteirinho - 04-07-2006, 04:52 PM
DANCO - irishtwincam - 04-11-2006, 06:26 PM
[] - Rasteirinho - 04-12-2006, 10:35 AM
[] - jamiemirror - 04-12-2006, 01:45 PM
[] - Rasteirinho - 04-15-2006, 01:05 PM
[] - Ivan141 - 04-26-2006 11:47 AM
| Bigger brake master cylinder options | Koen | 10 | 3,807 |
01-08-2026 03:12 PM Last Post: r.ave |
| 4AGE cylinder head plug removal | Ivan141 | 5 | 5,868 |
| Brake advice - master cylinder | mannix20vt | 12 | 20,520 |
| Radiator oem or upgrade on racecar? | Jimmi The Kid | 5 | 8,764 |
| Ta60 carina steering upgrade? | Allexz | 15 | 22,077 |
06-01-2016 08:12 AM Last Post: Allexz |
