Upgrade Brake Master Cylinder
04-12-2006, 11:45 AM
That is where you are mistaken. Increasing the master cilinder diameter will lower your line pressures, so you'll need to push the pedal harder to make up for the difference. Since you can have better pedal feel with more resistance from the brake pedal it might feel like an improvement because you can modulate the braking force better, but it's not an upgrade. The formula for line pressure is P=F/A, where P is pressure F is force and A is area. The force exerted on the brakepads follows the same formula where F=P*A. So you see that you will have to apply more force to get the same result.
I do think it might be a worthwile thing to do to get that pedal to feel a bit less sloppy, but it wont make the car stop faster if that's what you think.
We have an excelent thread on brake tech, you can find it here:
http://www.aeu86.org/viewtopic.php?t=388...c&start=25
should be a sticky...
Messages In This Thread
[] - Mux213 - 04-07-2006, 01:23 PM
[] - jamiemirror - 04-07-2006, 02:09 PM
[] - Mux213 - 04-07-2006, 02:21 PM
[] - jamiemirror - 04-07-2006, 02:23 PM
[] - Mux213 - 04-07-2006, 02:27 PM
[] - Rasteirinho - 04-07-2006, 02:29 PM
[] - jamiemirror - 04-07-2006, 02:35 PM
[] - Mux213 - 04-07-2006, 02:37 PM
[] - Rasteirinho - 04-07-2006, 04:52 PM
[] - dAYTONA - 04-07-2006, 09:27 PM
[] - meshin - 04-11-2006, 05:43 PM
DANCO - irishtwincam - 04-11-2006, 06:26 PM
Re: DANCO - El_Camino - 04-11-2006, 08:03 PM
[] - Ivan141 - 04-12-2006, 08:34 AM
[] - Rasteirinho - 04-12-2006, 10:35 AM
[] - Ivan141 - 04-12-2006 11:45 AM
[] - robokill - 04-12-2006, 01:40 PM
[] - jamiemirror - 04-12-2006, 01:45 PM
[] - Mux213 - 04-12-2006, 02:29 PM
[] - Mux213 - 04-12-2006, 02:40 PM
[] - Ivan141 - 04-12-2006, 03:46 PM
[] - Rasteirinho - 04-15-2006, 01:05 PM
[] - Mux213 - 04-25-2006, 04:35 PM
[] - Ivan141 - 04-26-2006, 07:45 AM
[] - NoHachi - 04-26-2006, 09:42 AM
[] - Mux213 - 04-26-2006, 11:23 AM
[] - Ivan141 - 04-26-2006, 11:47 AM
  Bigger brake master cylinder options Koen 10 4,231 01-08-2026 03:12 PM
Last Post: r.ave
  4AGE cylinder head plug removal Ivan141 5 6,012 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 20,759 08-21-2017 03:21 PM
Last Post: Project D
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 8,931 06-23-2017 05:21 PM
Last Post: pack
  Ta60 carina steering upgrade? Allexz 15 22,424 06-01-2016 08:12 AM
Last Post: Allexz
