Type of carbs to suit 4ag
01-29-2013, 07:28 AM
hi all i am just wondering if DRLA carbs of a Alfa Romeo Boxer engine would be good for 4age carb setup. here is a link http://www.trademe.co.nz/Browse/Listing....=554344434
01-29-2013, 08:47 AM
NO.
01-29-2013, 12:04 PM
Carb on 4AG = DCOE or Keihin FCR, nothing else !
01-29-2013, 01:00 PM
I've run my 4AGE with Keihin CVK 40 from (i think) ZZR900 without any problem. Runned like a charm.
TRD put some Dellorto dhla 48 on their N2 cars. Seen may Solex runned 4AGEs also. Just be sure the are sidedraft. These AR ones from boxer are not best choice since they are downdraft. btw. FCR .. yeah right.. they cost more than most 4AG's ![]() |
01-30-2013, 07:27 AM
FCR cost routly the same price than any kind of carbs setup (I'm talking about brand newparts of course)
A brand new Weber 45 cost around 400€ each and you need 2 of them. So they also cost more than most 4AG too... |
01-30-2013, 06:52 PM
I consider used prices, you are right for new ones.
45mm carbs are much more hard to find, even used go easy for 500+/set. Used 40mm Webers and Dellortos in 40mm are supercheap and easy to find. I thing they are great for all 4AGE up to ~160hp. |
01-31-2013, 07:30 AM
Thank you all. anyone selling in new zealand for smallport carb set up let me know. another thing to ask power 160hp thats insane!! on my other post some one has a down draft to suit the webbers. now if i was to buy that and go with webber would i be looking at 160hp?
01-31-2013, 08:44 AM
FCR? what sort of manifold goes with these? are they as good like DHLA and DCOE?
01-31-2013, 10:44 AM
FCR are by far the best carbs you can get for throttle response !
For the manifold, if you know an aluminum welder, that's really easy to do. Some brand like RS-Chita in japan sell manifold specially made for FCR application: http://www.rschita.jp/fcrcab.htm For hp, the fact than you can go[u:038703656f] up to[/u:038703656f] 160hp with 40mm carbs doesn't meen you will get 160 with just carb ! You need few other things to get that kind of power like good camshaft etc... PS: carb have to be tuned with the engine. Don't expect to get your car running like a charm after you install them. Also a carburator setup cost a little less on parts itself compared to throttle bodies, but it's way more time consumming to fine tune. |
01-31-2013, 11:37 AM
Project D Wrote:For hp, the fact than you can go up to 160hp with 40mm carbs doesn't meen you will get 160 with just carb ! How awesome would that be, slap carbs and get 160hp ![]() |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,987 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 12,602 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 5,167 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 14,035 |
05-04-2015 01:17 PM Last Post: Project D |
ford type 9 gearbox with 4age engine | filh | 29 | 51,695 |
01-11-2015 01:02 PM Last Post: filh |
