Tuned 4AGE results
07-12-2013, 08:40 PM
Post: #51
Tuned 4AGE results
Project D Wrote:If I can add few things up about makkuro's setup.
The engine head, apart from the parts mentioned earlier, is absolutely stock. (Not ported)
Also, he still use the stock ECU
1st: 148hp (135rwhp) @ 7327rpm and 158Nm (116.6ft-lbs) @ 5294rpm
2nd: 146.2hp (133rwhp) @ 6868rpm and 163.3Nm (120.5ft-lbs) @ 5308rpm
3rd: 147.4hp (134rwhp) @ 7059rpm and 162Nm (119.5ft-lbs) @ 5191rpm
Was this with a small or big port head ?
What induction system ?
07-12-2013, 10:06 PM
Post: #52
Tuned 4AGE results
It's a bluetop, so bigport.
For the induction: stock manifold with the T-VIS and a Injen filter, IF I remember.
Makkuro should be able to tell you more (after all, it's his engine)
07-19-2013, 10:30 PM
Post: #53
Tuned 4AGE results
Project D Wrote:It's a bluetop, so bigport.
you are right. it is an injen filter.
my toyota is fantastic
  Max a 16v 4AGE can be tuned to? heshan 20 63,790 04-21-2009 08:31 PM
  Silvertop burning oil - compression results Jezza_hr 3 5,837 10-18-2008 02:51 AM
Last Post: jondee86
  AE86 Dyno Results! Wraith 9 16,933 10-16-2006 09:13 AM
Last Post: Mux213
