Toyota Carina 1uzfe swap
09-12-2013, 12:11 AM
so, avensis coilovers fit the s13 hub??
Do they need any modification to fit? ![]() ![]() ![]() |
09-12-2013, 09:31 AM
ts@n@k@s Wrote:so, avensis coilovers fit the s13 hub?? Basically yes,just took about 2mm with grinder from the hub where coil mounts |
10-18-2013, 04:53 PM
Little update:
Not having much time, so work goes slowly on car. Added strutbrace, mounted rear bmw suspension, and put wheels back.Now there is little problem with engine, it starts and runs fine, but when you drive it, it feels like 100hp car. I have cheked every thing, know the last option is to change spark plugs, rotors and covers, waiting to get them. If not, then I dont know, maybe wiring issue. I added small video, walk around the car. ![]() ![]() Need to figure something out with bottom shock mounts. ![]() ![]() Need to adjust front wheels hight, lower it a bit, also add front chin spoiler. ![]() |
10-19-2013, 09:08 PM
crazy bitch.. well done...
Maybee one day :wink: JZD |
10-20-2013, 11:19 AM
Finally its running like it should. Problem was in wiring, only 4 fuel injectors was connected, so only 4 cylinders was working. Hoked up "+" to right side injectors and BOOM, engine now are like rocket
![]() https://www.dropbox.com/s/58z1glre0ls0pi...163138.mp4 |
10-28-2013, 09:41 PM
Toyota Carina 1uzfe swap | |||
10-30-2013, 11:19 PM
Where did you get the chin spoiler from?
10-31-2013, 08:53 AM
banpei Wrote:Where did you get the chin spoiler from?From another thread karos Wrote:cannabolic Wrote:Hey, what lip, spoiler did you use as front lip? ![]() Philip |
11-01-2013, 08:06 PM
11-04-2013, 09:15 PM
It looks brutal!
![]() Want to trade with a mint Carina? ![]() cannabolic Wrote:Lip is from old Lada..Thanks! ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
82 Carina TA63 | DGealon | 9 | 15,728 |
10-21-2016 04:38 PM Last Post: banpei |
Toyota Carina TA62 4A-GE 16v Redtop | nyberrg | 18 | 32,368 |
02-05-2016 09:40 PM Last Post: nyberrg |
My Carina TA60 | crxman | 17 | 22,546 |
01-09-2016 10:17 PM Last Post: nyberrg |
Project "Roku-ju" TA60 Carina | Motax | 24 | 41,909 |
03-05-2014 10:21 AM Last Post: Motax |
McKenney's 1UZFE Kouki Levin Coupe | McKenney | 2 | 10,713 |
03-12-2013 04:53 AM Last Post: McKenney |
