The Truenos Transformation
04-26-2007, 09:55 PM
Post: #51
in the UK if a car has no MoT you are not suppose to drive it on the road unless it is to a local MoT station
i my case the MoT station was 60 miles away so was no within reasonable distance so i had to trailer the car there
plus i am not supposed to do any real milage on the diff untill i have ran it in which i have not done yet Sad
plus the car was nt taxed that makes it worse as well lol
[Image: AEU86 AE86 - The Truenos Transformation]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
04-27-2007, 01:30 PM
Post: #52
Ah, that explains a lot Smile
04-28-2007, 12:32 AM
Post: #53
got a box today
had something i have wanted since i bought the car
can yoiu guees what it is
yup standard wing mirrors to get rid of the nice gay M3 ones
ebay bargain at £30
went and got a price for getting the bonnet sprayed
£150
this includes geetting the bonnet done
getting the headlight covers redone
wings blended in
and mirrors painted
getting it a bit cheaper because my mate works there Big Grin guy that done my MoT
05-24-2007, 03:28 PM
Post: #54
well here is an update for you all
the car is not back on the road yet as i had hoped
ran into a problem where the car was not acclerating right, or going hrough the rv range quick enough, we thought it was an ignition problem
so changed the leads/dizzy cap/rotor arm/plugs
this did not sort the problem
so next thing we checked was the timing which was out slighlty, after we sorted thiswe could not even get the car to start, so next up was a compression check
which gave these results
here are the figures
dry
1 130
3 155
2 103
4 112
wet
1 135
3 163
2 120
4 132
according to the books
min is 142 and max 179 with a max of 14psi differance
so strip the head off to discover one fucked head gasket
and once fucked cylinder number3 and a fucked piston Sad
so i ordered a new TRD 0.8 metal headgasket as it was cheaper than a standard one
it got delivered by a courier but it was fcuking well folded in half
contacted fensport they went apeshit and are sending me a replacment asap
in the meantime i have decided to scrap my engine as it is an early model 3rib big port engine
going to go with an engine from a AE92 FWD corolla as it is the later 7rib smallport engine so better for further modification in the future
all that is left to go is the gearbox now and when that goes i am fitting a supra box instead of the T50 as it is cheaper and stronger
05-24-2007, 03:47 PM
Post: #55
Quote:all that is left to go is the gearbox now and when that goes i am fitting a supra box instead of the T50 as it is cheaper and stronger
You have easy acces to A->W adapter bellhousings?
05-24-2007, 03:58 PM
Post: #56
not sure yet
not looked into it properly yet
05-24-2007, 11:16 PM
Post: #57
meh not as cheap as i first thought
http://www.phpbber.com/phpbb/viewtopic.p...xcouk#3559
05-25-2007, 09:31 AM
Post: #58
Thats what I thought..If you go through the trouble of buying adapter bellhousings, might as well spend the extra money on the 6-speed from the NC miata. For near stock torque numbers (aka anything non FI) the stock T-50 box is fine if you're not a complete moron. Some people can wreck anything, but that has little to do with the equipment imho.
05-25-2007, 08:31 PM
Post: #59
I just cut the oe t50 bellhouse open toward the gearbox, and then weld it to the gearbox,
You can still take the gearbox apart for rebuild ,if needed!
I´m this weekend making 2pcs. bellhouses ready, to weld on the w58gearbox.
/Skassa
"""www.turbotoys.dk"""
06-06-2007, 08:20 PM
Post: #60
well should be getting hold of a replacment engine soon, thank feck
going to rebuild it with all new parts
water pump
oil pump
ACL RACE SERIES Crankshaft Main Bearing Set Standard Size (5M1695H-STD)
ACL RACE SERIES Connecting Rod Bearing Set Standard Size (4B1780H-STD)
ACL RACE SERIES Thrust Washer Set Standard Size(2T1695)
http://cgi.ebay.com/ebaymotors/88-CHEVRO...QQtcZphoto
full engine full gasket set
ARP flywheel bolts(already got these)
new pistons, and piston rings(standard)
new plugs
new timing belt and fan belt
going to be about £200 for all the parts
majority of parts are coming from america
planned mods
PASS racing underdrive pulley kit
lightweight one peice illegal garage driveshaft
lightweight 212mm flywheel
  OST-069: Transformation oldeskewltoy 19 19,446 01-14-2021 04:41 PM
