The Big Yins 86
11-21-2005, 01:21 PM
The Big Yins 86
Only had the car a few days and I have discovered sme nice surprises on it which is saving me money.
It already has a 4-1 manifold
Full Sports Exaust
Adjustable shocks front and back
Front Adjustable Camber
Front strut brace
and a HKS Mushroom Filter
I dont have any plans to strip the car out........... yet but that may come in the future you never know I might put a rear cage in it.
Already ordered are, Toda Racing Cams
ECU Toda N1 chip and a SAFC
Going to Order a clutch in next few days
Parts still to get
FORGED PISTONS- (JE)
PULLEYS-) (hks)
VALVE SPRINGS (hks)
lowering Springs 40mm springs Bilstein i think
Car goes into my local Jap specialist Hypertech clicky on Wednesday for a full check over
Then on thursday it goes into a local body shop to get the 2 rear arches sorted, just under the boot and undear the rear passnger window, all rust spots so gettin it all done just now before it gets worse
[Image: AEU86 AE86 - The Big Yins 86]
11-21-2005, 01:22 PM
The Big Yins 86
That car is such a beauty! Sounds like you gonna take good care of her to, good boy! Smile
11-21-2005, 02:19 PM
The Big Yins 86
Howdy Yin,
I have some nice fidanza cam gears that I could sell you. They are brand spanker new and great quality. They are still in their shiney new boxes. They are at least as good a quality as the HKS ones.
Let me know if you are interested.
Regards Ian.
11-21-2005, 02:27 PM
The Big Yins 86
Fidanza Adjustable Cam Gears
Regards Ian.
11-21-2005, 05:03 PM
The Big Yins 86
i just wanna ask, why is it good to have all those ground leads? arent the stock ones alright? i am also missing some ground leads (like the hood-2-ground, and perhaps some other. everything works fine. i've seen people really invest in taht so i would like to know whats the big deal?
11-21-2005, 06:03 PM
The Big Yins 86
It is said that they provide a shorter groundpath, which would have positive effects on the ignition and maybe even injectors. I'm not too sure if it really helps though. The most reputable maker of these hyper-ground or whatever they are called kits is SUN auto from japan. They ask quite a bit compared to the ebay crap but they do have dyno sheets showing a slight improvement.
11-22-2005, 01:34 AM
The Big Yins 86
they were already on the car when i bought it, going to a rollin road day on thew 8th december to find out what she is putting down, i want to know before i start to mod her
11-22-2005, 12:08 PM
The Big Yins 86
well here is a picture of the cams, bought them fr $575 so £340 bloody bargain consideruing they are £270 + vat here in the uk
11-23-2005, 07:20 PM
The Big Yins 86
my car just came back from its checkover and here is some of the stuff i need done
getting a organic clutch
needs all fluids changed, brakes, need checked and cleaned, possbaly replaced, spark plugs, leads, both drive belts cracked and worn, one of my rear shockies is seized, PAS steering belt pretnsioner badly worn(squeel) and a few other things needing done lol, so this stuff is more important
11-23-2005, 11:11 PM
The Big Yins 86
both front A/R/bar links worn
slight play on both front hub bearings
slight play on o/s/r rack end
slight play on o/s/r track rod end
HKS filter needs its filter replaced (a green one)
both drive belts worn and cracked
PAS steering belt tensioner bearing badly worn
oil level just above min recomend changing all fluids
N/S/R dampening adjuster seized
Clutch Assembaly Required ASAP
slight whine from diff(nothing to worry about)
all breaks require strippingand cleaning (possably need to replace dics and pads)
all work to be started 2morrow
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 6,358 09-09-2022 09:07 PM
Last Post: Vaptor
  AE86 N2 (big update) 86Pilot 110 175,523 09-06-2013 11:33 AM
Last Post: Apsogos
  3AGE-AE86 NZ [big pics warning!] WELL 9 17,116 04-17-2007 07:48 AM
Last Post: domi
  Big brakes on my SE-86 at last. Billzilla 12 20,164 09-13-2005 04:07 PM
Last Post: Billzilla
