The A6 Celica/Carina topic
05-04-2008, 06:05 AM
Post: #291
I guess I dont need a spare set, but that's hoarding for ya.
Difference between lights.... ![]() Facelift on top, prefacelift on bottom. Facelift have the headlight surround that goes along bottom and top of the lights, prefacelift have the surround only going around the bottom and sides, the bonnet trims them off at the top. The indicators are smaller on facelift ones, they go between the top and bottom surrounds, instead of just above the bottom surround. Also, the front grill is different, I think the prefacelift grill is wider from memory. I ended up swapping grills with 'toyota loyal' because he had prefacelift lights with a facelift grill, and I had vice versa. The twin round lights setup uses prefacelift twinsquare indicators and grill BTW. |
05-04-2008, 09:40 AM
Post: #292
Ah okay... So I bought a set of facelift headlight and now I need to find facelift indicators since mine is prefacelift.
05-05-2008, 02:25 AM
Post: #293
You're also gonna have to chop off some brackets to suit the headlights you've currently got, and the mounting points on the gaurds are slightly different too.
Choppity chop! |
05-05-2008, 03:43 PM
Post: #294
Auch!
Edit: just won a GT-TR badge. ![]() I'm actually not going to do any badgetuning, so don't worry... The idea is to remove the -TR and make mine a GT when the 4AGE is in it.
05-09-2008, 06:20 AM
Post: #295
I thought the 4age carina should be GTR.. whereby the GT should be the older version 2TGEU which I'm Havin...
![]() http://www.revolverdrift.blogspot.com |
05-09-2008, 06:21 AM
Post: #296
![]() This is for sale but in malaysia.. with a 4age... very std specs from the pics.. ![]()
05-09-2008, 04:06 PM
Post: #297
Is that a factory rear spoiler?
Looks pretty tidy dude! Much rust? |
05-09-2008, 04:49 PM
Post: #298
gsrturbo Wrote:I thought the 4age carina should be GTR.. whereby the GT should be the older version 2TGEU which I'm Havin...Nope, GT badge was also used for the 4age versions after it replaced the 2TG I figured out that the R-badging is the "racing" spec because the R-versions feature "bucket"-seats (ahem!) and have stiffer springs. I collected the specs some time ago here: http://www.banpei.net/page/carina-a6-specifications And while you're already browsing my site then, please also check this Carina Coupe engine swap I found yesterday: http://www.banpei.net/content/carina-a6-...2lt-diesel >
05-10-2008, 04:20 PM
Post: #299
It's interesting that the TA64 celica group B car used a live axle instead of the IRS setup.
I wonder why? I've heard somewhere else (cant remember) mention that IRS is no good for rally, perhaps if you need heaps of suspensions travel then having a diff go straight up and down is better than IRS going through an arc. *shrug* Obviously most/all modern rally cars are IRS, perhaps they use something different to the older style trailing arm setup. I wasnt fussed whether I got an IRS or live axle carina, both have their ups and downs. Although I'm sure the IRS one is more comfortable when just cruising etc. (Not that that's what mine is gonna be for |
05-10-2008, 08:54 PM
Post: #300
Celica IRS axles do have the nasty tendency to react heavy on lowering the suspension. You get MASSIVE camber gain when the car is lowered or raised. And with big travel suspension like used in rally, that means A LOT of camber change.
I think the modern cars use double wishbones i guess, less camber gain
| Another rusty old carina. | roman | 8 | 18,806 |
08-20-2007 12:56 PM Last Post: roman |
| Amazing -musseum ready- Celica | nmwisima | 26 | 34,317 |
03-13-2006 12:42 AM Last Post: The Doctor |
| ST185 celica evo 500 | SekiguchiUeno | 2 | 6,548 |
02-25-2006 08:53 AM Last Post: banpei |
| Check out that old CELICA!!! | nmwisima | 12 | 18,666 |
07-10-2005 10:09 AM Last Post: banpei |
![AEU86 AE86 - The A6 Celica/Carina topic [Image: AEU86 AE86 - The A6 Celica/Carina topic]](http://img73.imageshack.us/img73/5809/carinalightszn2.jpg)
![AEU86 AE86 - The A6 Celica/Carina topic [Image: AEU86 AE86 - The A6 Celica/Carina topic]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - The A6 Celica/Carina topic [Image: AEU86 AE86 - The A6 Celica/Carina topic]](http://img315.auctions.yahoo.co.jp/users/7/2/2/4/dndnn400-img600x450-1209557839p1010126.jpg)
![AEU86 AE86 - The A6 Celica/Carina topic [Image: AEU86 AE86 - The A6 Celica/Carina topic]](http://i90.photobucket.com/albums/k244/gsrturbo88/celica/ol%20Skool%20Car/Signatures_carina.jpg)
![AEU86 AE86 - The A6 Celica/Carina topic [Image: AEU86 AE86 - The A6 Celica/Carina topic]](http://i262.photobucket.com/albums/ii120/ke1788/DSC00273.jpg)
