Techno Toy Tuning 4 Link Kit
10-11-2007, 03:43 PM
Hi!
What do you think about the TTT 4 Link kit in combitnation with the Panhard / Lateral Bar?! http://www.technotoytuning.com/productdetail.php?p=688 Is this good stuff?! |
10-11-2007, 05:22 PM
Jup. But most of the 4 link kits out there are fine..T3 looks pretty though
10-11-2007, 06:01 PM
well very fine quality products with teflon coated bearings, but are you sure you need this set? for track use or good quality roads no problems but poor quality roads can twist you chassis, unibal bearings cannot absorb vibrations as rubber or polyurethane.
my idea is 4links on Pu or hard rubber and maybe unibal panhard rod for road use http://www.86ers.org All the hachies that Daytona can only dream about. |
10-11-2007, 07:18 PM
Thanks for your opinions.
Maybe I´ll buy the panhard rod from TTT and traction brackets and use the stock 4 link units with aftermarket bushings..... |
10-11-2007, 07:51 PM
I have the T3 panhard rod in combination with the stock 4links on PU. I really like this setup and wouldnt think about buying the T3 4 links. Besides, I do recommend a T3 panhard rod because it takes away the wiggle of the rear when cornering on a rough road.
10-11-2007, 09:26 PM
Gabriel Tyler from TTT says, that they have 2 ae86 with this 4 link kit and they use their cars as daily drivers and doenst have any problems with this kit,....
10-11-2007, 10:30 PM
AshCampbell Wrote:Gabriel Tyler from TTT says, that they have 2 ae86 with this 4 link kit and they use their cars as daily drivers and doenst have any problems with this kit,.... yeah.. it shouldnt be a problem but I agree with Seki. Consider it carefully thinking about what roads you usually drive. If you drive on tarmac the most of the time I would say why not.. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
10-12-2007, 10:10 AM
Only Tarmac
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 13,540 |
07-21-2014 09:12 PM Last Post: Bean |
| Wanted: Link to Beams Blacktop engine manual pdf | irishtwincam | 7 | 14,470 |
01-03-2014 11:31 AM Last Post: irishtwincam |
| Mumford link | Lajoosh | 4 | 9,363 |
11-27-2013 09:01 AM Last Post: Lajoosh |
| Ecu ROM tuning | Alex170984 | 4 | 7,899 |
10-13-2013 08:03 AM Last Post: Apsogos |
| Need help (4ac engine tuning) | fullybuiltmiata | 3 | 8,526 |
08-20-2012 09:25 PM Last Post: banpei |
