TVIS probloms
07-29-2008, 06:06 PM
TVIS probloms
HEy guys i don't kwon if my TVIS is working so i don't know how to test it i know that it works by vacumm '85 Corolla Sprinter Trueno GT-APEX |
07-30-2008, 08:12 AM
TVIS probloms
What are the symptoms? If the TVIS isn't working correctly you should have less torque in the lower rpms.
You can test it by revving it above 5000 rpm on the throttle and look around the vacuum canister under the TVIS: it should open (above 5000rpm) and close (under 5000 rpm) the butterflies when working correctly. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
07-30-2008, 03:42 PM
TVIS probloms
Well it's hard to rev it to 3000 RPM but after that the engine works good
08-01-2008, 06:03 AM
TVIS probloms
More info needed! What's hard about getting it to 3000rpm? Is it slow going, does it splutter (technical term
)?When you say it's good above 3000, do you mean runs normally, vibrations, noise, emissions? |
08-10-2008, 12:36 AM
TVIS probloms
CoolinAE86 Wrote:Well it's hard to rev it to 3000 RPM but after that the engine works good That isnt your TVIS. What does your engine diagnosis tell you. Ecu could be in limp home mode because of a simple sensor error or vacumm leak. Could be a busted h/gasket aswell. Steve.....this is sparrrrrtan |
08-12-2008, 05:52 AM
TVIS probloms
Make sure that you're vacuum lines are connected right with the EVAP canister.
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,966 |
| 20v silvertop exhaust manifold on 16v 2nd version tvis motor | Apsogos | 17 | 29,358 |
| my tvis doesnt work... | daywalker | 30 | 60,561 |
02-19-2012 01:25 PM Last Post: ZDoman |
| technical asking about TVIS | filh | 4 | 7,972 |
02-27-2011 02:07 AM Last Post: filh |
| TVIS close ignition switch??? | juantonwan | 2 | 5,035 |
07-27-2010 12:17 AM Last Post: totta Crolla |
![AEU86 AE86 - TVIS probloms [Image: AEU86 AE86 - TVIS probloms]](https://www.aeu86.org/sticker-banner-468.gif)
