TRD spring pressure rate??
01-07-2008, 05:10 PM
Hi
I got a second-hand TRD suspension and I'm not sure what pressure rate the springs is..
Is there some way I can finde out what the pressure rate is, fore example by measuring the wire diameter??
thanks
01-07-2008, 06:09 PM
Try this link:
http://www.stockcarproducts.com/pstech10.htm
01-07-2008, 06:34 PM
Who did you buy them from?
[Image: AEU86 AE86 - TRD spring pressure rate??]
01-07-2008, 08:13 PM
I dont know how accurate this is but makes sense. In the spring you can find the part number. The part number is followed by 2 digits, this digits lets you know the spring rate.
For example, a rear spring with 48231-AE801-65 on it, means 6,5 kg.
Cump“s
Filipe Oliveira
01-08-2008, 03:04 PM
totta Crolla Wrote:Try this link:
Thanks, I'll try it and see if it makes any sense.
Jan P: I belive it's from the red coupe K-POWER had years back..
Lipinhu: Thanks but unfortunately you can't see the part number on them any more..
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 25,751 08-19-2018 12:08 PM
Last Post: AlexKTM
  SOME 4AG valve spring specs oldeskewltoy 5 16,177 05-04-2015 01:17 PM
Last Post: Project D
  Oil Pressure Query Alex170984 2 6,730 12-11-2014 01:25 AM
Last Post: Alex170984
  Pressure gathering in fuel tank Apolan 9 19,061 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 26,000 09-29-2013 12:06 PM
Last Post: allencr
