TRC issue beams into ae86
10-06-2009, 07:03 PM
Hi guys, my name is jorge and I´m from Costa Rica Central America. I´m on the way to end my project which is a turbo black top beams into my AE86 for drifting. I have the stock computer and and greedy turbo kit. Have a few questions about the traction control wiring and ecu....
1-What you do with the traction control, do you use it?
2-If not, how you overcome this?, I found in the traction control wiring there´s a lot of ABS wiring also, so if I ended cutting those....it would affect the engine response/performance?
3-I have the possibility to use an AEM stand alone....could I get rid of that traction control unit/ecu?
4-Could I change the intake plenum for another one that didn´t utilize the traction control unit?
Thanks A LOT for the help....
10-07-2009, 06:20 AM
When you say black top beams I assume you mean a 3S engine. I have no experience with these, but if you do use a standalone computer you will be able to remove all traction control functions.
If the traction control unit on the throttle body is non functional there shouldn't be a problem with leaving it, unless it causes issues with normal throttle/airflow operations.
  PWR light issue and no brake fluid after winter storage magpie 10 5,097 05-25-2023 08:09 AM
  Fuel pump issue DJexor 11 7,782 04-29-2022 05:45 AM
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 11,477 12-19-2021 11:58 PM
Last Post: gh0st
  Clutch Issue Deaty 8 5,891 04-09-2021 10:26 PM
Last Post: Nakilad
  5th gear issue r.ave 1 3,502 03-14-2021 08:52 PM
