TODA Pistons
09-02-2008, 10:00 PM
TODA Pistons
I want to change the pistons. I found some TODA's pistons.
http://todaracingusa.com/category?sectio...d=25&id=85 I want to buy the 82mm and 20pin. Is the compression ratio like a standard 11,3:1 with oem headgasket? If i want low it? What is the meaning "over sized"? **COROLLA EE80 - 4AGE 124HP**
09-03-2008, 05:34 AM
TODA Pistons
Oversized means that the bore size is larger than stock. Lowering the compression is by usingh a thicker headgasket.
09-03-2008, 04:00 PM
TODA Pistons
So the TODA's pistons have standard compression. And i can adjust the compression with a headgasket?
But the wiseco pistons have compression ratio for 10,3:1 to 11,8:1. **COROLLA EE80 - 4AGE 124HP**
09-03-2008, 09:04 PM
TODA Pistons
No the toda pistons have 11:1 and higher compression ratio's.
But the whole point of these pistons is the higher compression. You could lower it a bit by installing a thicker headgasket, but then why not just buy a thinner headgasket for your current engine and accomplish the same thing? FABRICA MI DIEM, PVNC! |
09-03-2008, 09:30 PM
TODA Pistons
i have problem with some rods in the bottom end. And i rebuilt a 4agze bottom end with high compression pistons
09-22-2008, 04:25 AM
TODA Pistons
The reason to use such nice pistons is added protection against detonation and for lighter weight. Plus when running higher lift cams it will reduce your dynamic compression.
09-22-2008, 07:07 PM
TODA Pistons
so is it good to reduce the dynamic compression?
09-23-2008, 01:18 AM
TODA Pistons
tolisspi Wrote:so is it good to reduce the dynamic compression?no :lol: |
10-04-2008, 09:25 PM
TODA Pistons
So i bought toda 82mm and 20 pin withoem headgasket the compression ll be 11,3
10-06-2008, 06:11 AM
TODA Pistons
I'm quite newb in those things but the dynamic compression isn't it reduce buy hi-duration cams hier than hi-lift cams...?
SR Team BURN THE RUBER NOT YOUR SOUL! |
| 82mm Stock compression Pistons | apardal | 4 | 5,389 |
| Kelford vs Toda | Gates Racing vs Toda for 16v | mister86 | 2 | 5,940 |
06-10-2020 04:43 PM Last Post: Lykowsky |
| TODA head assemble | Jimmi The Kid | 5 | 9,276 |
03-05-2018 08:37 PM Last Post: Jimmi The Kid |
| Toda Cams | Alex170984 | 7 | 12,281 |
02-11-2017 05:50 PM Last Post: Alex170984 |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 7,401 |
