Suspensions and stearing setups
01-06-2007, 08:44 AM
Post: #41
Abe Wrote:The end... 0º Toe helps a LOT. Glad you have it sorted. Caster you might want to think about reducing to 2.5º and hammering your inner fenderwells/pinchweld to clear the tire/turning radius. Extremely nice for response when doing fast corners/slalom type driving For drifting I run 3.5º+ camber But had great results for grip with 2.5º Taka Aono in his national champion SCCA track car ran: 2.5º camber 0º Unfortunately I can't remember what his caster was set too. Andrew |
| Possible turbo setups for the 4age. | wannabeadrifter | 3 | 6,242 |
10-29-2009 06:15 AM Last Post: wannabeadrifter |
| what do you use like suspensions ? | Spy | 40 | 57,463 |
04-14-2009 10:20 PM Last Post: Uzelac |
| What are your ignition timming setups? | Rasteirinho | 1 | 4,059 |
02-27-2008 08:42 PM Last Post: Rasteirinho |
| Electric fan setups | Ivan141 | 22 | 33,849 |
01-05-2005 10:55 PM Last Post: KristianAE86 |
, I cant prove it all, because the road not is good... but I have very good impresion at this moments...
