Suspension swaps from other cars ?
01-15-2012, 03:25 PM
Hey everybody,
I have been looking for answers but can't seem to find them. The front AE86 suspension - including strut spindle and front axle hub What other car brands or car types have almost the same identical stuff that you can maybe swap out with the AE86... Or perhaps make it even better? Especially the spindle and the front axle hub I need to know of. Thanks. -DWG- Drift Wolf Gaming |
01-15-2012, 03:35 PM
you can make the Nissan 200sx suspension work on the front... it needs some adjusting though as the nissan lower arms are ~50mm longer.
So either you make sure to accommodate the wider track and run quite a lot of camber and wider fenders or you stay with the AE86 lower arms and make the balljoint fit the nissan spindle. Best solution to get a bit of both is probably a custom lower arm to give more track but not too excessive. Another benefit of the nissan spindle (s13) is you keep the same wheel PCD and can use their brakes which have a lot more aftermarket support etc.. AE86 ex-daily |
01-15-2012, 03:46 PM
Wow! Thanks Bean!
01-15-2012, 04:00 PM
more info somewhere in here:
http://www.aeu86.org/viewtopic/ae86/t/54.../start=423 AE86 ex-daily |
01-15-2012, 04:49 PM
Ford escort mk2 suspension swap
see my technical topic about suspension. |
| Springs from other vehicles?? | FanIsHere | 16 | 18,653 |
05-17-2016 09:12 AM Last Post: FanIsHere |
| AE86 Body Panels - From Other Toyotas? | yellowsnow4free | 5 | 9,573 |
01-24-2013 04:19 AM Last Post: yellowsnow4free |
| track questions:max oil/water temp,egt and other | ditn | 7 | 9,857 |
07-06-2012 12:40 PM Last Post: ditn |
| Do UK/Euro cars have an illuminated fog light switch? | Lauren | 9 | 12,006 |
08-22-2011 08:53 PM Last Post: Lauren |
| 4AGE 20v Buy new clutch kit or other options | JAVResistance | 2 | 6,029 |
05-13-2011 08:02 PM Last Post: Jimmi The Kid |
