Suspension questions...Need quick response...
07-19-2009, 06:00 AM
I am starting an ae86 project with an empty shell. It has no suspension or anything else in the front, just the body. I need to know what parts are compatible between the corolla and the celica/supra.
07-19-2009, 02:30 PM
With the Celica Supra? I presume you mean the A6 Celica Supra... Not much I guess! Blush
Think stuff like pedalbox, brakebooster, wipermotor, etc. would fit, but they are not the same.
Suspension is different, but probably the front strut will fit: AA63 struts do fit the AE86 but could give you positive camber...
Engine could be fitted since someone already managed to shoehorn a 7MGTE into an AE86, but it takes heavy modifications to do so...
Rear setup it totally different (IRS vs live axle) so if you want to reuse that you need some big modification to make that fit as well...
[Image: AEU86 AE86 - Suspension questions...Need...esponse...]
07-19-2009, 02:38 PM
well I am doing a ka24de swap... Ive been doing research on swapping the s13 suspension into the corolla any ideas?
07-19-2009, 03:59 PM
http://forums.club4ag.com/zerothread?id=33878&page=1
Here's some info on Ka24de swap and doktor on this forum has done a ke70 + ka24deT swap into his rolla.
I think Zax project topic is worth looking into, as he's doing the s13 swap.
Good luck Thumbs up!
Philip
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 9,148 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 5,019 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 17,155 01-03-2019 04:54 AM
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 40,236 06-27-2018 11:15 PM
Last Post: Ryo
  Quaife quick rack totta Crolla 19 28,948 03-03-2018 03:32 PM
Last Post: Deuce Cam
