Stock 4-link lengths?
10-29-2009, 01:53 PM
Hi guys,
Adjustment on my 4-links is way off, want to start from scratch using stock values as a baseline. Does anyone have some stock 4 link - bars that they could do a measurement on? Preferably from center to center. Would be much appreciated.
10-29-2009, 09:10 PM
L1 = 473mm
L2 = 244mm stock lateral bar mounting points distance = 800mm |
10-29-2009, 09:24 PM
Thanks for taking the time to measure those Lajoosh!
10-30-2009, 02:49 AM
x2
11-01-2009, 10:58 PM
Gentlemen! i need your help!
would be somebody so kind to measure a set of adjustable 4links and panhard rod. preferably t3 or BV. i need the rods lenght by themselfs, without the joints and lock nuts. |
11-02-2009, 01:40 AM
I have a battle version set on mine. Will measure them for you when i go to set up the car (its parked in a garage outside of my city). Hopefully next weekend.
11-04-2009, 02:14 PM
NoHachi Wrote:I have a battle version set on mine. Will measure them for you when i go to set up the car (its parked in a garage outside of my city). Hopefully next weekend. thanks! please do! counting on you. |
11-05-2009, 12:04 PM
NoHachi, can you also measure spacers for 4-links?
owau no ka "I" |
11-05-2009, 12:24 PM
Spacers will be difficult as everything will remain on the car. They depend on the type of rod-end used anyway.
11-05-2009, 03:55 PM
most of rod-ends are identical in size
the 4-link used 16mm inner dia, panhard 20mm. but ok, I'll measure stock link thickness. this will be enought owau no ka "I" |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 2,901 |
| 82mm Stock compression Pistons | apardal | 4 | 4,825 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 17,486 |
| Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 7,635 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
| stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 7,336 |
02-20-2016 11:48 AM Last Post: Bean |
