Steering U-Joint
02-02-2012, 01:33 PM
Steering U-Joint
Hi, my steering U-Joint is worn on my treuno.
Its got a manual rack on it.
I ordered a U-Joint from a MR2 MK1 but it doesn't fit as both ends have a 1cm where as the 86 U-Joint is 1cm the steering wheel end, and 2cm the steering rack end.
Can someone tell me where I can get another one from? Which car can I get one from? Or a part number? Or does anyone have a decent one to sell me?
Really need one ASAP.
Any help is greatly appreciated.
Thanks,
02-02-2012, 05:29 PM
Steering U-Joint
Toyota PN: 45209‑32010
http://www.toyodiy.com/parts/p_E_1987_TO..._4501.html
02-03-2012, 10:50 PM
Steering U-Joint
Thanks for the PN but where can I get this part from?
02-03-2012, 11:44 PM
Steering U-Joint
Your Toyota dealer :wink:
02-05-2012, 05:40 PM
Steering U-Joint
I have now found that its not a manual steering rack. Its a power steering rack with the power steering taken off.
Is this still the same part number?
Its 1cm at one end and 2cm at the other.
Please help.
02-07-2012, 07:05 PM
Steering U-Joint
If it's 45209‑32010 you want, then your spoilt for choice, as it was fitted to many Toyota models.
Here's a list of possibles...
http://shkgiec.en.made-in-china.com/offe...2010-.html
The MR2 AW11 u/j is p/n 45209-17010 and is supposed to fit when swapping to a manual rack. [I think it's the same as above, though].
One p/n for AE86 u/j with power steering is 45209-12040. That could be difficult to find.
You might also want to have a look at http://www.modified.com/projectcars/0712...ewall.html to see the parts side by side.
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 2,237 04-26-2025 03:24 PM
Last Post: DaLanZhu
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 52,505 10-02-2014 06:07 PM
  Propeller shaft universal joint kawo 1 5,564 05-19-2014 11:05 AM
Last Post: Uzelac
  Steering U-joint welded - options? Rear axle ? ggrahl 9 11,527 12-26-2011 06:41 AM
Last Post: ggrahl
  U-joint on drive shaft - Beams 6s box KD2229 3 6,431 08-18-2011 03:59 AM
Last Post: KD2229
