Starting probs
11-07-2006, 02:57 PM
Starting probs
I just got a dli system put in and have had a couple of probs wif starting. the starter turns the engine over, but not enough for the crank angle sensor to create enough voltage to spark the plugs. was thinking bout a better battery, ie from a diesel? any ideas, all i need is the starter to crank a bit faster. It only happens when the engine is really cold and has sat overnight, once its warm it starts 1st time everytime. really need help on this one.
Its gotta go whoosh or give a whine!!!!
11-07-2006, 04:23 PM
Starting probs
Before you start switching parts around, try to check whether the starter is in good working condition (the collars that act as bearings tend to wear out over time). After that try improving the voltage supply and earthing of the starter..thicker then stock wires and perhaps a more direct connection.
11-07-2006, 05:00 PM
Starting probs
i havent got the facilites until late december. the starter is good, rebuilt it 8 months ago new bushings. all i need is a little more of a kick.
11-08-2006, 02:29 PM
Starting probs
I don't believe that is the exact case here, but if you say so, it probably is...
Try to check how far your hall sensor (or induction sensor, don't know which is, probably inductive sensor with one wire) is from the plate on the crank plate that is giving him the signal. The further the sensor is from the plate (the teeth that triger him) the weaker the signal is... and vise versa...
But it's probably just weak contacts, mass contact ore weak battery...
SNO-MO-BIRU project started- CHIRO
11-08-2006, 09:11 PM
Starting probs
it was on 20w 50 oil and sitting outside all night in 0-3 degrees celcius
the oils was just too thick for the starter to turn at the correct rate enough to send the signal to spark. Sorted it today and its starting great now, but thanks for your ideas. Thumbs up!
  lntermittent starting totta Crolla 6 7,077 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 5,258 08-31-2021 06:20 PM
  JDM trueno not starting. need help! kazi 8 13,057 03-12-2017 05:05 PM
Last Post: kazi
  20v Starting Issues mad.matt 10 17,281 09-24-2014 12:44 PM
Last Post: pack
  starting/electrical issues Jezza_hr 14 25,534 12-21-2013 05:45 PM
Last Post: Apsogos
