Starter problems
09-01-2005, 11:00 AM
Starter problems
You reach the contact just with unscrewing two screws at the back of the starter and removing the metal cap.
I've made the new contact myself, you only need a piece of copper about 2.5mm thick and some ammount of patience...
I used the second method to take the starter in and out. I didn't have to go under the car to reach the heat shield's screw to unscrew the shield. A also removed the oil filter, to put one hand under the exhaust header.
To get the starter out of the engine bay is complicated, as Ivan already described, but to get the starter back in is twice more complicated. This is because you have to screw the starter's shield when the starter is already inside (under the exhaust header). So you don't see the screw, as in my case the lower exhaust heatshield wasn't dissasembled from the exhaust header...
Regards
Andrej
09-01-2005, 11:19 AM
Starter problems
Thanks!
Method 1 sounds like a no-go at the moment...
Hmmm, sounds like a lot of work since my car was lowered by TE71Corolla and thus leaving less space from underneath. Also sounds like I might need to use a bridge to reach it. I'll have a look at it tonight.
[Image: AEU86 AE86 - Starter problems]
09-01-2005, 12:09 PM
Starter problems
You could try to see if you can get a jack under the crossmember and then lift it up and put it on axlestands..
09-01-2005, 09:55 PM
Starter problems
Okay. That was a total waste of time...
I couldn't reach it at all with a hammer from the enginebay and the car is too low to crawl underneath and apply the hammer. I do have a jack (oem), but no axlestands so I was not going to risk breaking my neck (or some other bodypart) by crawling underneath and try to reach it and the jack tipping over...
So I tried to follow the cables from the enginebay but I could not see where the cables came from or went to. Probably one of the cables packed in a tube which go to the engine for all I could tell. Then it went too dark to see and I gave up. Undecided
09-01-2005, 11:15 PM
Starter problems
Art, I need to get my drive on things to you, then we can easilly get underneath your car safely...
I don't know if there is a chance you can get over here tomorow night?
09-02-2005, 08:15 AM
Starter problems
BTW, the hammering bit involves a metal pipe or broomstick of some sort so you can reach in there...doubt if it would have done any good..Your starter would have been fried if it was stuck and you push-started the car.
09-02-2005, 12:04 PM
Starter problems
mux213 Wrote:Art, I need to get my drive on things to you, then we can easilly get underneath your car safely...
Nope. My sister in law has graduation today, so I don't have time today. Undecided
12-28-2005, 01:43 AM
Starter problems
Jan Pedersen Wrote:This is what you need:
anyone has partnumbers for those things? Dumb question
Disclaimer: Any errors in spelling, tact, or fact are transmission errors.
12-28-2005, 08:54 AM
Starter problems
I'll try to get a hold of the part numbers next time I pay a visit to my part pusher Smile This buy is the only one I can't find the reciept for...
01-03-2006, 08:37 PM
Starter problems
"Piston" 28235 - 35080
Fittings are aftermarked from a company that has specialized in starter rebuilds, but bought at Toyota. If you are not able to get them order this part number: 28226 - 72080 (Actually for E101, but they should fit the E86 as well) Problem is that this way you are not only getting the fittings, but some extra parts which makes it more expensive Sad
Hope this helps Wave
  Big wheel problems gh0st 16 13,709 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 4,410 08-31-2021 06:20 PM
Last Post: totta Crolla
  AE86 starter options max_ae86 12 36,111 07-28-2019 08:17 PM
Last Post: harkes
  Problems Mintex M1155 pads Dino86 9 12,064 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 6,095 07-04-2015 01:00 AM
Last Post: jondee86
