Squeaking noise from engine
08-24-2011, 07:21 PM
Hey guys, theres a terrible squeaking noise coming from my engine when it´s idling. Almost the same noise like a sliping disk brake.
When reving the engine, the squeaking leaves but comes back in idle.
Does anybody have an idea what it could be?
AE86 Full Hybrid - Burns rubber and gasoline
08-24-2011, 07:57 PM
Loose or overtight belt?
08-24-2011, 08:21 PM
So i just figured out that it´s also there while driving, but only when releasing the throttle and just letting it roll.
But sometimes it squeaks and sometimes it don´t Banging head
I´ll check the alternator belt tomorow. Can it also squeak when it´s too tight Dumb question
Should i also check the timing belt - i actually thought that it can´t squeak because it can´t slip...
On the other hand i don´t think it´s the alternator belt, this would be louder.
Damn... Angry
08-25-2011, 07:00 AM
It's more than likely a belt. If you push on the belt and it gives more than 2cm's it is to loose. It should only give about 1cm. If it is to tight It won't give. I'm assuming that this belt has been on for a while though, so it is more than likely loose. You can also pick up a product at your local parts store. It's a spray that removes the built up grease on the belts, but isn't corrosive enough to eat the belt itself. Here's a link n how to use it.
http://autorepair.about.com/od/quicktips...essing.htm
Understeer is when the front end hits the wall.
Oversteer is when your back end hits the wall.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you!
08-25-2011, 04:13 PM
Well, the belt tension is ok as i expected. I overhauled the engine only a few months ago so this was supposed to be ok.
Used such a spray on my old winter beater, i´ll see if it helps here.
08-25-2011, 05:35 PM
Hope it goes well!
08-25-2011, 05:39 PM
in case it doesn't if you can record the sound and post it we might recognize it better.
08-25-2011, 09:11 PM
Could be a small air leak.
Unlikely but it would be worth checking the cambelt idler pulley.
  Clutch rattling noise on deceleration pack 7 1,788 11-06-2025 12:43 PM
Last Post: pack
  TRD Short Shifter Rattle Noise, It's Normal? Mattolo 19 25,118 04-27-2024 10:04 PM
  Clicking noise from glove box chrisae86 4 4,033 09-08-2022 11:36 PM
Last Post: chrisae86
  Noise Insulation for AE86 decryphe 1 5,249 11-03-2016 11:51 AM
  Whining noise HELP PLEASE izanagi 10 15,327 03-26-2015 06:48 PM
Last Post: Komba
