Spring
08-10-2005, 10:23 AM
Spring
I need some springs for my new koni sport
where can i buy TRD springs i want 6kg an 4kg |
08-10-2005, 01:08 PM
Spring
Is it AE86 long type of konis on front, or short one?
Fun is not the straight line! |
08-10-2005, 05:57 PM
Spring
it is the long type not short stroke
08-10-2005, 08:56 PM
Spring
WeRz, send a PM to Rikard (member of this board), he might be able to get them for you.
08-11-2005, 02:08 PM
Spring
Be careful with long conis, because for higher (5kg+) spring rates you will have to put shorter springs to achieve normal ride height. That will cause undesirable free space between strut and spring. Only if you want to prepare your Hachi for Paris-Dakar….
| SOME 4AG valve spring specs | oldeskewltoy | 5 | 16,349 |
05-04-2015 01:17 PM Last Post: Project D |
| clutch pedal return spring | Eifelaner | 2 | 9,086 |
09-06-2013 10:21 AM Last Post: Apsogos |
| P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 4,500 |
04-05-2012 04:17 PM Last Post: Dino86 |
| lowering spring information HELP | martyg | 1 | 4,447 |
09-27-2011 01:56 PM Last Post: martyg |
| clutches and spring washers position in 2 Way TRD diff???? | T_AE86 | 3 | 6,797 |
09-01-2011 10:50 AM Last Post: T_AE86 |
