Speed sensor
12-27-2008, 03:26 PM
Speed sensor
Can anyone tell me what the effect of running the car without the speedo cable attached to the gearbox would be ?
Diagnostic test brings up a code 9 fault "speed sensor" which is not surprising as the speedo cable does not fit the Ford gearbox I have fitted !
12-28-2008, 12:24 AM
Speed sensor
There is a reed switch in the speedo that outputs a pulse to the ECU.
AFAIK it is only used to activate a speed cut on some models. If the
signal is missing it throws a fault. For what its worth, I ran my car with
the speedo cable disconnected a couple of times, and didn't notice any
change in performance, and don't remember getting a CEL.
Cheers... jondee86
12-28-2008, 10:43 PM
Speed sensor
Mux drove his car with a broken speedo cable for some time... Can't remember him getting faultcodes either.
[Image: AEU86 AE86 - Speed sensor]
Big Grin map sensor cheating? fdsjakl890 8 4,242 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,741 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 25,055 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 11,223 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 14,620 10-25-2013 05:13 PM
Last Post: Apsogos
