Speed Sensor Location?
01-25-2008, 03:10 PM
I'm having a problem with the speedometer not working in my 86 and one thing that was suggested was that I check the speed sensor.
Anyone know where the speed sensor is located? Everything else works on the dash so it makes sense that the sensor might be faulty.
Thanks,
Matt
01-25-2008, 03:46 PM
If you have the analogue cluster the speedometer cable is going from the gearbox to the back of the speedometer. The back of the speedometer picks up the revolutions of the cable and translates them into the speed. So the sensor is inside the cluster itself.
If you have a digital cluster the sensor is inside the gearbox and sent electronically to the cluster.
[Image: AEU86 AE86 - Speed Sensor Location?]
Big Grin map sensor cheating? fdsjakl890 8 3,998 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,401 05-23-2022 10:00 PM
Last Post: The Doctor
  Placement location fuel filter bozu 0 4,971 12-01-2016 11:06 AM
Last Post: bozu
  AE86 Engine Coolant Temp Sensor izanagi 8 24,791 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 11,022 02-28-2014 10:07 AM
