Silvertop Install, Clutch Flywheel problems, please help!!
08-03-2008, 10:16 PM
If I remember correctly, there are thrust washers on the crankshaft
to control the forward and back movement. Without reference to the
manual, I can't say the standard clearance. However, it will be quite
small, probably no more than 0.5mm.
When you say the clutch grabs... does it just give a tiny movement,
or does the car actually jump forward by some distance ?? The
release bearing that comes with a FWD clutch kit is completely
wrong for a T50 setup. Did you change the release bearing ?? Did
you install a spigot bearing in the ST flywheel ??
Cheers... jondee86
Messages In This Thread
[] - robokill - 08-03-2008, 09:07 PM
[] - jondee86 - 08-03-2008 10:16 PM
[] - byd1380 - 08-03-2008, 11:35 PM
[] - jondee86 - 08-04-2008, 02:37 AM
[] - byd1380 - 08-04-2008, 12:03 PM
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 9,284 05-26-2024 07:40 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 16,168 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 5,273 08-31-2021 06:20 PM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 18,909 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  TUV RHD AE86 Germany (help please) 4dori 9 11,789 07-17-2019 07:42 PM
Last Post: Hachigo83
