Silvertop Install, Clutch Flywheel problems, please help!!
08-03-2008, 08:09 PM
I installed a Silvetop in my MG midget, previously running a large port 4AGE. I installed the original gearbox and fitted a new clutch kit. The problem is, when you press the clutch pedal and select a gear, then rev the car hard (4-500rpm), the car jumps forward as if the clutch has been released. I have taken the clutch apart and nothing obvious seems to be wrong. I am now concerned that there is movement in the flywheel. If I get a large screwdriver and place it between the block and the flywheel I get slight movement, is this normal?
Thanks
Ivan
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
Messages In This Thread
Silvertop Install, Clutch Flywheel problems, please help!! - byd1380 - 08-03-2008 08:09 PM
[] - robokill - 08-03-2008, 09:07 PM
[] - jondee86 - 08-03-2008, 10:16 PM
[] - byd1380 - 08-03-2008, 11:35 PM
[] - jondee86 - 08-04-2008, 02:37 AM
[] - byd1380 - 08-04-2008, 12:03 PM
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 9,480 05-26-2024 07:40 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 16,444 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 5,365 08-31-2021 06:20 PM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 19,047 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  TUV RHD AE86 Germany (help please) 4dori 9 11,958 07-17-2019 07:42 PM
Last Post: Hachigo83
