Sick little Hachi
11-06-2006, 09:22 PM
Sick little Hachi
This is what you need to do:
http://www.club4ag.com/faq%20and%20tech_...0Codes.htm
Otherwise we will just keep on guessing from a distance..
11-06-2006, 09:49 PM
Sick little Hachi
Cheers Nohachi,will try this and let you know how i get on.
The A.d.d Clinic
Automotive Detailing:
http://www.addperformance.ie
[email protected]
JDM Import specialist:
A.d.d - Ireland
11-09-2006, 02:35 AM
Sick little Hachi
Hi Guys,
Went out to the car today and did the diagnostic check looped the wire in the diagnostic port and watched.here's what happened:
The engine check light flashed 5 times
then paused for 0.5 sec and flashed 6 times
then paused for0.5 sec and flashed 10 times
Does this mean there is a code 56 wrong with the car and if so what is code 56??,also can anyone tell me what the flashing 10 times is about.
Anyway i then disconnected the NEGATIVE on the ECU and went about cleaning all the EARTHS on the car,when i reconnected the ECU and started it was fine.Drove great for the whole evening
Can anyone put a bit of light on this (hope it behave's,fingers X'd)
The A.d.d Clinic
[email protected]
A.d.d - Ireland
11-09-2006, 10:20 AM
Sick little Hachi
cab32,
A good! Atleast you got her driving again!! Bad grounds suckBig Grin
As for the codes, good question, I think its time someone put a nice little writeup up about checking the error codes with a nice list of what they mean, who feels up to it? Wink
11-09-2006, 12:15 PM
Sick little Hachi
Hi mate,
It feels great have her back on the road again,will start doing a bit of research into the error codes.Thanks again Smile
The A.d.d Clinic
[email protected]
A.d.d - Ireland
11-09-2006, 02:28 PM
Sick little Hachi
Mux213 Wrote:As for the codes, good question, I think its time someone put a nice little writeup up about checking the error codes with a nice list of what they mean, who feels up to it? Wink
robokill? Tongue
cab32, good that you got the car running again with no problem at least now. I hope the problem will gone forever Thumbs up!
11-09-2006, 02:49 PM
Sick little Hachi
there are codes http://www.troublecodes.net/Toyota/
OBD1 Codes
1 Normal Condition.
2 Air Flow Meter signal.
3 Ignition signal.
4 Engine Coolant Temperature Sensor signal.
5 Oxygen Sensor.
6 RPM signal (Crank Angle Pulse).
7 Throttle Position Sensor signal.
8 Intake Air Temperature Sensor signal.
9 Vehicle Speed Sensor signal.
10 Starter signal.
11 Switch signal.
11 ECU/ECM.
12 Knock Control Sensor signal.
12 RPM signal.
13 Knock Control CPU (ECM).
13 RPM signal.
14 Turbocharger Pressure.
14 Ignition signal.
21 Oxygen Sensor.
22 Engine Coolant Temperature Sensor signal.
23 Intake Air Temperature Sensor signal.
24 Intake Air Temperature Sensor signal.
25 Air-Fuel Ratio Lean.
26 Air-Fuel Ratio Rich.
27 Sub Oxygen Sensor signal.
28 No. 2 Oxygen Sensor signal.
31 Air Flow Meter signal (Vacuum Sensor signal).
32 Air Flow Meter signal.
34 Turbocharger Pressure signal.
35 Turbocharger Pressure Sensor signal.
35 HAC Sensor signal.
41 Throttle Position Sensor signal.
42 Vehicle Speed Sensor signal.
43 Starter signal.
51 Switch signal.
52 Knock Sensor signal.
53 Knock Sensor signal.
54 Inter-cooler ECM signal.
71 EGR System.
72 Fuel Cut Solenoid signal.
78 Fuel Pump Control signal.
81 TCM Communication.
83 TCM Communication.
84 TCM Communication.
85 TCM Communication.
also in here http://www.club4ag.com/faq%20and%20tech_...0Codes.htm
11-09-2006, 06:49 PM
Sick little Hachi
It was probably spitting 3 codes..
11-13-2006, 05:48 PM
Sick little Hachi
Hi guys,
Big thanks for the help it's been a few days now and all is still good,cheers Oldskull for the nice comments hope it lasts for good as well mate. And S.K thanks for the codes,big help to alot of people mate.And yes Ivan141 i think you are probably right about the car spitting out three codes.5 , 6 and ten 10 all make sense.
Thanks again guys,hope i can be of help to you sometime. Big Grin
The A.d.d Clinic
[email protected]
A.d.d - Ireland
  Trueno Conversion but with a little twist / question. Okami 16 19,460 05-19-2012 06:41 AM
Last Post: danielt
  Little starting Problem AshCampbell 5 7,586 06-04-2009 07:50 AM
Last Post: jondee86
  Oil pump pics/info - a little help? assassin10000 1 4,002 01-31-2009 06:57 PM
Last Post: assassin10000
  Need a little HELP with the diff rebuild lamera 5 7,007 03-29-2007 11:48 PM
Last Post: lamera
  had a sick idea... WKD RWD 9 10,522 02-16-2006 10:52 PM
Last Post: dAYTONA
