Short stroke suspension
10-11-2012, 11:45 AM
Take a look here Lajos, those GAZ dampers should suit your rates very well, are adjustable through a large range and should be a decent length for AE86s
http://rallyspares.tripod.com/id74.html Or http://www.ebay.co.uk/sch/i.html?_nkw=es...&_osacat=0 Send them a mail about the attachment method and their lengths. At 75€ each new you won't find a better deal around or a better match to the ae86 chassis. A wheel to steer the front of the car A pedal to steer the rear |
10-13-2012, 06:09 PM
Lajoosh Wrote:need info and axperience on this. My opionion, fronts whould work alright even tho I personally I dont like konis at all, cause of the stupid internal adjustment. Using them at the rear? Bollocks. You need serious short stroke shocks for the rear to get the most out of your coilovers, I´ve just gone rear coilovers and the cost about 320GBP build my specs with a sperical bearing and shorter than TRD blue shocks Bit more info in my build thread: http://www.aeu86.org/viewtopic/my-slowly...0/start=50 As we´re talking about GAZ shocks, the company I work for does a lot of custom supensions with them, they build us whatever we require, lenghts, diameters, mounting points... so literally anything is possible. I know what your company does, but I doubt by the end with buying AE92 fronts, springs, faffing about with getting it to work, you´ll waste time and probably end up more expensive. You´re much better of just to buy a set. If you intrested Pm me and I give you an acurate quote. ![]() 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 22,625 |
04-27-2024 10:04 PM Last Post: banpei |
Bilstein short strokes | Grant | 1 | 4,671 |
05-15-2012 07:32 PM Last Post: NoHachi |
Does anyone know where to buy a short steering hub/boss? | krullibull | 6 | 7,557 |
10-12-2011 10:26 PM Last Post: krullibull |
Long Stroke Springs - Espelier 40mm Tokico ??? | juantonwan | 20 | 19,681 |
05-11-2010 10:31 PM Last Post: jondee86 |
fc3s front brake conversion, short report | speed-inc | 18 | 18,118 |
10-09-2009 06:32 AM Last Post: aussiefan |
