Shims 20V Blacktop
12-23-2017, 05:23 PM
(This post was last modified: 12-23-2017 05:56 PM by CHOPKIN2.)
Shims 20V Blacktop
I am new to this. I am pretty sure I am missing shim parts. The attached photo is all I got when I took them off. All I got was the small little disc plates.
Based on what I saw on the TODA website I am missing two pieces. Am I correct? The forth picture shows someone's shims which look complete compared to mine. |
12-23-2017, 06:41 PM
Shims 20V Blacktop
it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off.
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-23-2017, 08:32 PM
| Shims 20V Blacktop | |||
12-23-2017, 11:07 PM
Shims 20V Blacktop
(12-23-2017 08:32 PM)CHOPKIN2 Wrote:(12-23-2017 06:41 PM)oldeskewltoy Wrote: it looks like your shims are inside your buckets. use a pair of needle nose pliers and see if that center bit comes off. no idea.... sorry Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 2,408 |
| 20v Blacktop conversion.... | Mylesmck | 0 | 1,207 |
04-29-2024 05:48 PM Last Post: Mylesmck |
| Improve 20V Blacktop cooling | pack | 0 | 1,756 |
06-07-2023 01:18 PM Last Post: pack |
| stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,929 |
02-20-2016 11:48 AM Last Post: Bean |
| Comp. Test - 20v Blacktop | hachirokkos | 2 | 5,830 |
01-10-2016 02:30 AM Last Post: hachirokkos |
