Settings for APEXi SAFC???
06-09-2005, 11:16 PM
The problem is that my car doesn't have a Pressure Signal cable in the 18p ECU socket.
What is the diagram for the MR2 i ' ll have to use Knudsen?
I think that they say that (for the throttle signal) cause they are talking about USA models with AFM (ours have MAP instead) right?
06-09-2005, 11:20 PM
It's a MAP one isn't it?
Well, the ECU HAS to have a pressure signal... I cant remember what diagram it was, and my manual isnt here with me. But the AW11, the AE82 and the AE86 all have the same ECU. :wink:
Are you absolutely 100% sure, that you have looked in the right socket and the right pinnumber? And that you dont have an AFM engine?
06-09-2005, 11:25 PM
Yeah thats a MAP engine... Im pretty sure, that you have mistaken the pin numbers. I remember, that its easiest if you take the plug out of the ECU and turn it 180 degree... Then its pointing in the same direction as in the manual.
06-09-2005, 11:29 PM
Oh man i made such a fool of myself!!!
I was looking in front of the socket man ... Banging head
Anyway i'm going to use the T1-a diagramm which is for the AW-11 right?
and of course the diagramm is for the ECU PINS and not for the socket pins right? Blush
06-09-2005, 11:35 PM
No, the diagram is for the socketpins. That means if you see the ECU from above with the sockets connected. As you can see, you have to turn the sockets 180 degree, cause the diagram is actually upside down :wink:
Im pretty sure that it was the AW11 diagram i used...
Ohh, and be careful when you connect the pressure signal. Its very important to connect it the right way. Nothing will get ruined, but the engine wont start if its connected wrong Confused
06-09-2005, 11:48 PM
Thanks a lot man!!! Thumbs up!
MUCH OBLIGED!!! Respect! Respect! Respect!
06-09-2005, 11:49 PM
Good luck! Just say the word, if it doesnt work out for you Smile
06-09-2005, 11:54 PM
Never been afraid to ask for help man!
Thanks for offering it that big way in here!!! Respect! Thumbs up!
06-09-2005, 11:55 PM
No problemo, my greek friend Wave
  Torque settings kazi 4 11,232 03-28-2017 12:15 AM
Last Post: kazi
  What do you guys think of the APEXi SAFC-II system? heshan 2 5,075 02-28-2009 10:32 PM
Last Post: heshan
  Settings for HKS 256 cams on stock engine Bean 7 11,031 03-16-2008 10:56 AM
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 18,772 03-12-2008 02:58 PM
Last Post: Roku_trueno
  Apexi Power FC Thor W 3 6,540 09-29-2007 12:42 AM
Last Post: SYM
