STL file for the early spec Levin headlight ball joint plastic clip
04-26-2025, 12:01 PM
I own a JDM Levin (early model), and the headlights were in terrible condition. The main problem is that the ball joint that holds the reflector inside the headlight is brittle and breaks, making it impossible to adjust the headlight properly. All the early spec headlights I bought so far had this issue, so I decided to create a 3D model for printing, which I want to share here.
![]() You can download the STL file from here. Use PA11 or PA12 (Nylon) as the material. It is heat-resistant and worked well for me. Again, this has only been tested for a RHD early model Levin, and I am not sure if it will work on LHD models. I used this on my own Levin to restore my headlights. If you need more instructions I wrote a summary on my website. |
04-26-2025, 12:36 PM
Thank you very much for sharing that! Good to see I'm not the only one duplicating and printing parts!
![]() BTW: Are you Clemens in Japan on Youtube? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
04-26-2025, 03:24 PM
Thank you! Yes, that's me. I haven't had much time recently for new videos, but the 86 made good progress. I recorded most, so hopefully at a later stage I can turn them into some fun videos.
Converting Jap Spec wing mirrors to UK spec | chrisae86 | 5 | 3,172 |
04-12-2022 11:03 PM Last Post: chrisae86 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 8,206 |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 17,994 |
09-19-2017 02:06 PM Last Post: banpei |
Trueno headlight help | kazi | 9 | 13,965 |
04-20-2017 09:37 AM Last Post: kazi |
TRUENO - LHD headlight solutions | pack | 11 | 15,195 |
09-21-2016 10:29 AM Last Post: pack |
