SR5 to GTS LSD conversion
09-27-2007, 12:14 AM
Ok, so I'm ready to begin the process of turning my sr5 into an actual drift car. I do plan on a 4ag swap down the road, but for now I figure switching from open diff to LSD is probably one of the first steps I should take. However, I don't really know much about differentials except where they are located and the theory of how they work. Can you put an LSD into an sr5 without doing an engine swap, and what does it involve?
AJC
'85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged
My Website
My Myspace
09-27-2007, 08:11 AM
Ofcourse you can do a LSD swap, but I think it probably won't make much difference unless you drive on roads with less traction. (e.g. wet tarmac, gravel, mud).
[Image: AEU86 AE86 - SR5 to GTS LSD conversion]
09-27-2007, 05:29 PM
Really? I was thinking it would help me with maintaining my drifts, instead of slowing down to exit... but I am still quite a novice so I'm probably wrong lol.
Also what would it take to do the swap? Obviously the LSD, but other than that would I need any other parts? I have rear drum brakes, not sure if that would be an issue.
AJC
My Website
My Myspace
09-27-2007, 05:57 PM
Well, it depends on what you call drifts then. Tongue
As for the parts: you need a 6.38 inch lsd. It is smaller due to the axle housing being smaller than the GTS housing, so a GTS lsd won't fit.
Another solution would be if you would swap the whole axle, but then you need to convert your brakesystem as well.
@86drift
Just use search, everything has been explained many times Thumbs up!
http://www.aeu86.org/index/engine-ae86-s...post=72098
  AE86 front end conversion Levin -> Trueno Electronics. gh0st 3 11,398 07-17-2021 11:20 PM
Lightbulb Deaty's GTS Project Deaty 9 8,969 04-27-2021 06:10 AM
Last Post: Deaty
  Sam's AE85 Conversion Sambo 2 18,083 05-20-2014 05:03 AM
Last Post: Sambo
  LHD to RHD conversion Gardo Yeidiem 1 7,443 05-05-2014 07:28 PM
  1986 Corolla SR5 S2k Build.... MIami style geoscranny84 16 28,275 04-26-2012 08:00 PM
Last Post: [Walaki]D`Lair
