SR5 to GTS LSD conversion
09-27-2007, 12:14 AM
Ok, so I'm ready to begin the process of turning my sr5 into an actual drift car. I do plan on a 4ag swap down the road, but for now I figure switching from open diff to LSD is probably one of the first steps I should take. However, I don't really know much about differentials except where they are located and the theory of how they work. Can you put an LSD into an sr5 without doing an engine swap, and what does it involve?
AJC '85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged My Website My Myspace |
09-27-2007, 08:11 AM
Ofcourse you can do a LSD swap, but I think it probably won't make much difference unless you drive on roads with less traction. (e.g. wet tarmac, gravel, mud).
09-27-2007, 05:29 PM
Really? I was thinking it would help me with maintaining my drifts, instead of slowing down to exit... but I am still quite a novice so I'm probably wrong lol.
Also what would it take to do the swap? Obviously the LSD, but other than that would I need any other parts? I have rear drum brakes, not sure if that would be an issue. AJC '85 GTS coupe - ghetto and half broken | '86 SR5 hatch - soon to be swapped & caged My Website My Myspace |
09-27-2007, 05:57 PM
Well, it depends on what you call drifts then.
![]() As for the parts: you need a 6.38 inch lsd. It is smaller due to the axle housing being smaller than the GTS housing, so a GTS lsd won't fit. Another solution would be if you would swap the whole axle, but then you need to convert your brakesystem as well. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
@86drift
Just use search, everything has been explained many times http://www.aeu86.org/index/engine-ae86-s...post=72098 |
| AE86 front end conversion Levin -> Trueno Electronics. | gh0st | 3 | 11,175 |
07-17-2021 11:20 PM Last Post: banpei |
| Deaty's GTS Project | Deaty | 9 | 8,900 |
04-27-2021 06:10 AM Last Post: Deaty |
| Sam's AE85 Conversion | Sambo | 2 | 17,830 |
05-20-2014 05:03 AM Last Post: Sambo |
| LHD to RHD conversion | Gardo Yeidiem | 1 | 7,332 |
05-05-2014 07:28 PM Last Post: Bean |
| 1986 Corolla SR5 S2k Build.... MIami style | geoscranny84 | 16 | 28,179 |
04-26-2012 08:00 PM Last Post: [Walaki]D`Lair |
![AEU86 AE86 - SR5 to GTS LSD conversion [Image: AEU86 AE86 - SR5 to GTS LSD conversion]](https://www.aeu86.org/sticker-banner-468.gif)
