SR20+AE86
03-23-2009, 08:33 PM
SR20+AE86
HI,
well this is My current project, this is what I have so far on my sr20de swap. IS been a couple of week since I started and justo did a Copy-paste from other forum. Motor SR20de from s14, motor arrived at my house on monday(thanks to miguel) Celica-Supra rear end( welded by Chopo performance) bar that goes under dif from MPV(modify to fit ae86 by Chopo Performance) front brakes from rx7 (Adaptadors created by chopo performance) steel brake lines all around bushings kit manual rack Gas pump from s13 engine and trans supports (thanks to baka..!) costum drive shaft (by v y v presicion) hopo to install these week end the engine. pics from things done so far. Free Image Hosting by ImageBam.com Ok this weekend I worked on: Getting costum made Clutch Installing front bushings INstalling tierods and suspension bars putting together front and back coilovers tacking out rearend hope will sell this ASAP just received hockey pucks for engine and trans supports Now I'm waiting for clutch, new supra rearend with previa punking whelded, need to buy all bolts tu put together trans and engine. will post pics tonight. I take a long time for the pics but they are here: Free Image Hosting by ImageBam.com Finally engine is on the car for the engine supports I use Hokey pukcs 1 on the rigth 2 on the left. for the trans support i used the 240SX stock one. brake Steel lines arrived. welded dif from a toyota previa arrive and ready to be installed on the supra housing. pics of me and some friends and my dad putting the engine on the car not as hard as some tell. Also having some Birria for Luch Pics: Free Image Hosting by ImageBam.com not much of work on the car this week had to work on saturday al day and just install the housing of the dif and al bars, today or tomorrow will put togeter the diff and leave it complete, the engine is fanally in the position where i can star making the header but due work I will wait all week. will put pics of the little work ASAP. |
03-23-2009, 09:00 PM
SR20+AE86
looks great man! keep up the good work!
03-30-2009, 08:34 PM
SR20+AE86
this weekend the work was:
try to restore rear brakes, result they will need to be replace with new ones. complete the instalation of rear end just waiting now for the brakes do a plate that will cover the previous hole for shifter put rear suspencion. put radiator(from a camry 90) and electric fans(Altima 93) fit berry nice this week will work on: rear brakes buy costum driveshaft hole for s14 shifter wiring (the big thing) hope will try to turn it on |
04-15-2009, 04:41 PM
SR20+AE86
hola red drifter, buena suerte con el swap.
good luck with the swap, it looks it's gonna come out really good, ready for some sideways action :wink: keep up the great work. Pedro Velado GT-S Owner
| AE86+SR20 | Rusticmeattank | 17 | 23,872 |
05-09-2010 11:38 AM Last Post: Eric |
