Richieu -Technical help desk
09-17-2005, 03:31 PM
James
Depending upon the size of the hole say no more than a finger nail, tap in the hole with a rounded hammer to make a crater. Put some filler on som card and stick it to the back of the hole (from inside if you can). If you cant do this use fibreglass bonding filler P38 and slightly fill the crater. Let this cure and then use an easy sand body filler to fill up the rest of the crater leaving the filler slightly proud of the hole. When this has gone off use some 120 grit paper and a rubbing block and move over the whole area untill the surface is smoothe with the rest of the panel. Then carry out the riming and painting as in the above post.
| Messages In This Thread |
Richieu -Technical help desk - richieu - 09-17-2005, 10:15 AM
[] - richieu - 09-17-2005 03:31 PM
$age Engine And Gearbox Problem... HELP - crucifycry - 08-24-2008, 04:35 PM
how can you close a sunroof manually - 3stoyo - 10-04-2008, 04:47 AM
[] - NightAddict - 08-31-2011, 10:32 PM
| Tomei 16V poncams + Tomei technical trax 1.5 way LSD | Lt86 | 22 | 28,823 |
09-16-2016 09:56 PM Last Post: Alex170984 |
| technical asking about TVIS | filh | 4 | 8,025 |
02-27-2011 02:07 AM Last Post: filh |
| www.aeu86.org Technical FAQ | Mux213 | 0 | 12,202 |
12-20-2005 06:45 PM Last Post: Mux213 |
