Red top in the ae86
04-27-2022, 06:13 AM
Red top in the ae86
As many pointed out to be 100% sure some closer investigation would be needed but I'd bet a beer what you have is a big port so going by the silly colour naming scheme a blue one.
AE86 ex-daily |
04-27-2022, 02:15 PM
Red top in the ae86
The easiest check is to compare the VIN to the engine block number to see if you have an engine swap. The engine block number is on the exhaust side near the flywheel. Also you can not go by 7 ribs. late model 1987 blue tops engines came with 7 ribs.
04-27-2022, 05:28 PM
Red top in the ae86
(04-27-2022 02:15 PM)Dave W Wrote: The easiest check is to compare the VIN to the engine block number to see if you have an engine swap. The engine block number is on the exhaust side near the flywheel. Also you can not go by 7 ribs. late model 1987 blue tops engines came with 7 ribs. I think I found it. Lets’s see i think says 201510505 My vin is AE86L-ECMQFW |
04-27-2022, 09:12 PM
(This post was last modified: 04-27-2022 09:43 PM by banpei.)
Red top in the ae86
(04-26-2022 11:27 PM)Nismo Wrote: Your engine maybe a redtop with an adaptor plate to fit the TVIS?To be honest I wouldn't know a sane reason why you would try to fit a TVIS on a smallport. The whole purpose of the TVIS is to have the ability to block off one of the two intake runners per cylinder, which increases the airspeed. This allows the engine to be more fuel efficient in low revs. The idea of the smallport is that the engine will have more torque in the lower revs (at the cost of fuel efficiency) while having a higher airspeed at higher revs compared to the bigport. The drawback is that due to the smaller ports the head is now more restricted in the amount of air/fuel mixture you can get into the engine (at high revs). Those two heads are basically meant for very different purposes. So the idea of fitting a TVIS to a smallport makes as much sense as fitting a TVIS to a 20 valve VTT head. (04-27-2022 05:28 PM)gh0st Wrote: I think I found it. Lets’s see i think says 201510505AE86L-ECMQFW is your model code. The VIN is the number is the one that starts either with JT2AE86... or AE86-0xxxxxx 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
04-27-2022, 09:37 PM
Red top in the ae86
Your VIN is here, will also be stamped on the plate, but this one is probably easier to read:
04-28-2022, 10:56 AM
(This post was last modified: 04-28-2022 01:20 PM by banpei.)
Red top in the ae86
(04-27-2022 09:12 PM)banpei Wrote:When my car came over from Japan, this is the setup I had, which I found strange.(04-26-2022 11:27 PM)Nismo Wrote: Your engine maybe a redtop with an adaptor plate to fit the TVIS?To be honest I wouldn't know a sane reason why you would try to fit a TVIS on a smallport. The whole purpose of the TVIS is to have the ability to block off one of the two intake runners per cylinder, which increases the airspeed. This allows the engine to be more fuel efficient in low revs. The idea of the smallport is that the engine will have more torque in the lower revs (at the cost of fuel efficiency) while having a higher airspeed at higher revs compared to the bigport. The drawback is that due to the smaller ports the head is now more restricted in the amount of air/fuel mixture you can get into the engine (at high revs). Those two heads are basically meant for very different purposes. There is only one true Nismo at AEU86 |
04-28-2022, 01:27 PM
Red top in the ae86
(04-28-2022 10:56 AM)Nismo Wrote: When my car came over from Japan, this is the setup I had, which I found strange.I still find it a strange decision. The only reason I can come up with is that they simply couldn't get their hands on a RWD converted smallport intake. It does take some skilled welding to convert it. Did they delete the TVIS butterflies or were they still present?
05-12-2022, 03:55 PM
Red top in the ae86
Just to confuse things a bit more........
The 1st gen largeport (1984-1987 **IF** original) is different from a 2nd gen largeport. The most obvious sign would be the front of the head - the casting is different. If you look down at the front of the head you'll either see a small gap between the cams, or not. The gap means a 1st gen head. No gap - 2nd gen head. ![]() If your plan is to build a standard valve head, I'd strongly recommend using a 1st gen head, as the casting is also different at the bowl! The 2nd gen head is better for a big valve head build.
05-13-2022, 09:56 AM
Red top in the ae86
Awesome information oldskewltoy!
What is mounted on the second generation where those two holes are? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
05-13-2022, 06:06 PM
Red top in the ae86
(05-13-2022 09:56 AM)banpei Wrote: Awesome information oldskewltoy!I might be completely wrong but I think it's for the engine mount AE86 ex-daily |
| Replacing Top Windscreen Moulding | chrisae86 | 2 | 4,161 |
| Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 9,814 |
| Silver top low idle | AlexFourTwenty | 7 | 14,072 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
| AE86 top mount | totta Crolla | 0 | 4,779 |
11-10-2016 08:04 PM Last Post: totta Crolla |
| 4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 14,360 |
11-02-2014 05:24 PM Last Post: ditn |
![AEU86 AE86 - Red top in the ae86 [Image: AEU86 AE86 - Red top in the ae86]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Red top in the ae86 [Image: AEU86 AE86 - Red top in the ae86]](https://gallery.ostportworks.com/albums/userpics/10005/4AGE_TVIS_heads_early_late_annoted.jpg)
