Red top in the ae86
04-25-2022, 04:27 PM
Red top in the ae86
Hello everyone,
I have a red top in my 86. I have read somewhere that a redtop came in the ae92 and the blue top in the ae86. Does that mean I don’t have the original engine in my 86?
04-25-2022, 08:45 PM
Red top in the ae86
Wanna post a photo so people can be certain?
But yes, if your car really has a redtop then it can't be the original unit.
04-26-2022, 08:16 AM
Red top in the ae86
(04-25-2022 08:45 PM)Power_uP Wrote:  Wanna post a photo so people can be certain?
Here is the photo:
[Image: AEU86 AE86 - Red top in the ae86]
04-26-2022, 09:32 AM (This post was last modified: 04-26-2022 09:36 AM by totta Crolla.)
Red top in the ae86
Well...
It's red!
TVIS suggests that it could be an early red top TVIS engine as opposed to the later smallport non-TVIS red top.
04-26-2022, 11:09 AM
Red top in the ae86
Having had the covers resprayed in red doesn't necessarily make it a redtop engine. It's most likely a bluetop that's had the cam covers repainted, but you're going to have to do some research to be certain which engine you have.
04-26-2022, 12:25 PM
Red top in the ae86
(04-26-2022 11:09 AM)Power_uP Wrote:  Having had the covers resprayed in red doesn't necessarily make it a redtop engine. It's most likely a bluetop that's had the cam covers repainted, but you're going to have to do some research to be certain which engine you have.
I know for a fact my engine has 124 hp. I read the ae92 redtop has 124 hp. A bluetop has 112 hp.
04-26-2022, 02:17 PM (This post was last modified: 04-26-2022 02:18 PM by r.ave.)
Red top in the ae86
and what facts are you talking about? dyno sheet?
Please see this video Banpei made a while ago with all the differences
I believe (based on the video) the bluetop makes 96kw = 130pk
04-26-2022, 09:52 PM (This post was last modified: 04-26-2022 09:55 PM by banpei.)
Red top in the ae86
(04-26-2022 12:25 PM)gh0st Wrote:  I know for a fact my engine has 124 hp. I read the ae92 redtop has 124 hp. A bluetop has 112 hp.
Don't believe everything what's written on Wikipedia: that's not written by professionals. Big Grin
The truth is that it really differs per car and per country.
It's true an AE86 bluetop outputs 112hp, but it does so in Californian spec including catalytic converter.
In Japan according to Toyota the AE86 bluetop outputs 130ps (which is 128hp). It did this with a catalytic converter but I highly doubt any factory new AE86 left the factory with 128hp. Japan was in HP wars back in the early 1980s and dynos have proved that they actually output around 120hp.
In Europe the output of the AE86 bluetop was rated at 124hp without catalytic converter and 116hp with catalytic converter.
In Switzerland the output of the AE86 bluetop was rated at 120hp without catalytic converter and 115hp with catalytic coverter.
However when you drive the cars, you won't find a lot of difference in power between all these engines. It's only 10% difference between the weakest and strongest engines.
The 4A-GE redtop is a very very different engine than the bluetop. And yes there were bluetops with red writing on them but that doesn't make them a redtop. It would have been much easier if they were named either bigport and smallport.
This is a redtop smallport 4A-GE:
As you can see it has a very different intake which is ribbed on top. This intake is a much simpler one due to the absence of the TVIS and it has slightly shorter intake runners.
From the side of the cylinderhead you can see why they are called smallport and bigport:
04-26-2022, 11:27 PM
Red top in the ae86
Your engine maybe a redtop with an adaptor plate to fit the TVIS?
The most accurate thing is to count how many ribs are on the the block and report back to us. If it is seven rib block then you know you got an AE92 engine.
There is only one true Nismo at AEU86
04-27-2022, 12:08 AM
Red top in the ae86
If you need any help identifying the block, there's a fantastic explanation in another thread here: 4AGE identification
  Replacing Top Windscreen Moulding chrisae86 2 3,549 06-18-2022 08:56 PM
Last Post: chrisae86
  Early tvis red top from e9 gti small or bigport? Ryo 3 9,140 04-20-2018 09:14 AM
  Silver top low idle AlexFourTwenty 7 12,900 10-16-2017 10:22 PM
Last Post: AlexFourTwenty
  AE86 top mount totta Crolla 0 4,183 11-10-2016 08:04 PM
Last Post: totta Crolla
  4age blue top from MR2 same intake manifold? dinkers542 8 13,118 11-02-2014 05:24 PM
Last Post: ditn
