Rear Half Shaft axles
12-06-2007, 01:24 AM
I have a GT-S LSD differential and i need to replace my right side half shaft because the guy who owned the car before me drifted into a curb., would a SR5 half shaft fit in ? or a zenki ? kouki?
12-06-2007, 01:28 AM
do you have a kouki or zenki lsd?
12-06-2007, 01:33 AM
I dont know ? all I know is on the back of the differential it says LSD and my car is a GTS model.
12-06-2007, 01:36 AM
what year is your car
12-06-2007, 04:21 AM
1986 why?
12-06-2007, 07:44 AM
Zenki = early model
Kouki = late model
This means that you properbly need a Kouki axle. But to make sure you'll need to take out an axle and messure how thick it is...
[Image: AEU86 AE86 - Rear Half Shaft axles]
12-06-2007, 08:49 AM
from Club4AG
http://www.club4ag.com/faq%20and%20tech_...ferentials
under 25mm Zenki
over 25mm Kouki
12-06-2007, 09:38 AM
thanks aussiefan for that info.
I looked at the pictures and my axle is the same as the picture on the right.
I'm guessing that there isn't a parts number for a half shaft.. is there?
12-06-2007, 09:54 AM
you're welcome
there are part numbers for that
i can take a look at Toyotas EPC when i'm at home
12-06-2007, 10:23 AM
And the only place you will get an axle from is another AE86 fitted with a T series rear end, nothing else is a direct swap without substantial machining/welding. S series (I presume SR5's have those in the USA) are different, including at the bearing collar (too narrow).
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 10,700 07-31-2019 11:28 AM
  Steering shaft issue Ryo 15 18,694 11-19-2018 09:52 AM
  Half Shafts Poblem AlexKTM 6 9,825 04-23-2018 04:42 PM
Last Post: MIGGZFSU
  Propeller shaft universal joint kawo 1 5,894 05-19-2014 11:05 AM
Last Post: Uzelac
  zenki and kouki model rear axles megabob 7 12,034 03-13-2013 08:43 PM
Last Post: megabob
