RCA or NRCA
04-16-2006, 06:35 PM
RCA or NRCA
Who have RCA or NRCA?
I'm looking for some pics of these to see if i can make a set from aluminum billet. I need the height and holes positions (specially for NRCA). Anyone can help me? |
04-16-2006, 10:51 PM
RCA or NRCA
RCA only:
http://samodisel.lorddigital.com/razni/A...nsion/RCA/ Duraluminium billet, coloured, anodised. I can measure some dimensions for you (these are 40mm thick). I can also made some (exactly) like these Keep in mind that you must use some steel inserts to prevent suspension bolts (look at original Toyota design).
04-17-2006, 02:45 PM
RCA or NRCA
The RCA thickness must be equal or close to the height you lowered the car.
For example, if i lower my car 40mm i sould have a 40mm thick RCA? For how much you sell RCA? It's worthless to fit NRCA instead of RCA? |
04-17-2006, 03:08 PM
RCA or NRCA
The RCA works as suspension geometry compensation. This is the reason that recommended thickness is close to height difference when you lower the car. I personally think that RCA can be a little thinner also. Your example sounds correct for me - you should use 35-40mm RCA to compensate bump steer. About NRCA - dig in club4ag.com forums - I think NRCA serves different purpouse also.
My promo-offer was 40EU/pair, anodised, including bolts, steel sleeves and washers (club member preordered these). Regular price is a little higher (~50EU for such set), the only problem is that I don't support quantities in stock (so I need some time to produce them but that way I can make them with custom thickness and color). |
04-17-2006, 07:23 PM
RCA or NRCA
OK,
As soon as i get my car ready and lowered i'll contact you... |
| RCA sizing | kazi | 3 | 6,823 |
01-28-2018 10:44 PM Last Post: kazi |
| lowering - adj. panhard rod & rca's & panhard bushin | Apolan | 8 | 10,301 |
05-24-2009 10:20 AM Last Post: Apolan |
| RCA question | Eric | 10 | 12,245 |
08-19-2008 10:18 PM Last Post: Eric |
| RCA doubt | hinachyo | 6 | 7,885 |
01-14-2007 11:07 AM Last Post: NoHachi |
| RCA in other cars? | Spitfire | 3 | 6,006 |
01-14-2007 06:27 AM Last Post: assassin10000 |
