Questions on my 4age??
05-12-2010, 12:50 AM
ok so i have a Frankenstein 4age not sure exactly wat i have but would like to know....my question is how can i tell which one i have without having to take it apart....i have no problem takin it apart its just i wont be able till next month.....this is my daily driver so i kinda need to know wat am runnin....also need to know so i can gap my spark plugs right.....is their anythin really wrong wit gapin them wrong??? cuz i know if its a smallport head i have to gap them .032 and if its a bigport i have to gap them .043 so kinda dont want to have wrong gapping cuz i dont know what the consequences may be.....i have looked up but i cant say i have gotten an answer so i decided to post...
05-12-2010, 01:24 AM
The easiest way to tell is .. Does it have TVIS intake? Does it have AFM or Map sensor? How many ribs are on the block 3 or 7?
05-12-2010, 03:00 AM
Smallport head has an external oil drain at the rear of the head on the
inlet side. A short hose that plugs into a hole on the block. Hard to miss ![]() Cheers... jondee86 |
05-12-2010, 03:41 AM
does not have tvis....AFM is their....dont know how many ribs i got since i havent opened thats y i was askin to see if their was another way lol
will check to see if the if the hose is their..... |
05-12-2010, 03:56 AM
No on the outside of the block under the intake you should see either 3 or 7 ribs/fins going up the side
like this I stole this pic from Banpei Its a 7 rib ![]() The large port intake will have 8 intake runners going to the head while the small port only has 4 Large port (blue top) ![]() Heres the top view of a red top (small port)
05-12-2010, 07:41 AM
ok kool thanks guys i finally found out wat am runnin....
running a 7 rib wit a big port no tvis
05-12-2010, 09:38 AM
And what you have on intake ?
05-12-2010, 03:29 PM
A bunch of carbs?
05-13-2010, 12:09 AM
well it dont say tvis on it so not really sure asumin i dont have any lol its a stock manifold lol wat more can i say i thought their were no tvis manifold and tvis manifold.....
05-13-2010, 12:14 AM
don't assume your crank. because the 7 ribbed lower block was first with a 40 mm crank with 18 mm pin. Compared to the late version 4age with 42 mm crank and 20 mm piston pin.
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 6,938 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 3,541 |
04-30-2024 09:46 PM Last Post: Mylesmck |
| Brake Bias Questions | mad.matt | 10 | 14,820 |
01-03-2019 04:54 AM Last Post: mad.matt |
| wider rear axle,track width,suspension questions | ditn | 6 | 11,813 |
| Suspension questions | leon205gti | 17 | 19,334 |
04-30-2016 09:26 PM Last Post: krullibull |
![AEU86 AE86 - Questions on my 4age?? [Image: AEU86 AE86 - Questions on my 4age??]](https://www.aeu86.org/files/4a/4age_7ribs_979.jpg)
![AEU86 AE86 - Questions on my 4age?? [Image: AEU86 AE86 - Questions on my 4age??]](http://i79.photobucket.com/albums/j133/jeremymarsh/Cars%20For%20Sale/Zmisc/IMG_3711.jpg)
![AEU86 AE86 - Questions on my 4age?? [Image: AEU86 AE86 - Questions on my 4age??]](https://www.aeu86.org/sticker-banner-468.gif)
