Question on rear quauter glass????????
08-13-2009, 07:40 PM
the passenger side rear quater glass leaks very badly! i was looking at the glass and i have no idea how to remove the glass Confused ??? lol. wondering if any body could help me out with this?
thanks
Matt
08-13-2009, 08:01 PM
Carefully (!) remove all the plastic window trimming (it clicks off with a bit of prying). Then unscrew the plastic tabs holding the window down.
Finally, carefully cut through any glue used to seal the window (start with a very small screwdriver or something to poke trough it and continue from there.
I'd clean all the old crap from the window and chassis, and use some fresh sealant to glue the window back in place.
One last tip:
Download the factory manual, it has all the details you need (you'll find it on the aeu86 homepage.
08-14-2009, 03:32 PM
Take the window trim off around the window on the inside - get a mate to hold the window in place and slide a blade down between the body and the window and slowly slice through the seal. Clean it all off once done with thinners and use silicone sealant in a tube to restick the window.
[Image: AEU86 AE86 - Question on rear quauter glass????????]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
08-18-2009, 01:52 PM
thanks for the help! Smile
Matt
Wink Can Wing Mirror Glass be Replaced? chrisae86 4 2,682 10-05-2025 11:09 PM
Last Post: chrisae86
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 7,470 10-20-2017 02:47 PM
  Rear Seat Belt Question sleepercivic 5 11,655 06-29-2017 09:30 PM
  Refurbishing Kouki "Glass" Grill mad.matt 5 8,013 09-24-2014 10:29 AM
  Rear ae86 rear discs & pad part numbers? J-86 4 7,324 11-30-2012 06:32 PM
Last Post: J-86
