Question about camshaft
07-04-2020, 06:37 PM
(This post was last modified: 07-04-2020 06:37 PM by CHACAMAN.)
hi, thans for time and help, guys i have a 4AGTE whit the next setup:
1 - Stock Big Port Head 2 - 4AGZE Block 3 - MegaSquirt II 4 - GT28 Turbo 5 - 7200RPM max i want to buy a camshaft for my engine i don't now what to buy, but I don't want to have to change the spirals and retainers, just install the cam and get more hp and torque ... What lift and what opening time do you recommend? http://www.ae86rd.com |
07-06-2020, 08:07 AM
(This post was last modified: 07-06-2020 08:09 AM by jondee86.)
Camshafts are not as important for performance on forced induction
engines as they are for naturally aspirated engines. When air is being pushed into the cylinder under pressure and there is a turbo in the exhaust, intake tuning and exhaust scavenging play a reduced part in overall performance. Of course, anything that helps the smooth flow of air (reduces resistance) will be beneficial, so a properly designed intake manifold, head work, decent exhaust manifold and correctly sized exhaust will help extract the maximum from your setup. Stock 4AGE cams work just fine for a lot of people. If you want to go further look for cams with more lift but without a lot more duration. Around 8.1-8.2mm of lift will work with stock springs, and duration in the 256-264deg (advertised) range. Kelford Cams make a set of 193-T turbo cams for the 4AGE with specs 262/266 Degrees advertised duration. 8.25mm/8.25mm lift. However if you look around you may be able to pick up a set of used HKS cams for less money. There is a fair amount of voodoo involved in matching cams and cam timing to a turbo. Your turbo needs to be matched to the engine to ensure that it operates in the higher efficiency part of its performance map. You will need adjustable cam gears and the makers of turbo cams often recommend uprated valve springs to make sure the valves close correctly at higher boost pressures. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
07-07-2020, 06:41 PM
(07-04-2020 06:37 PM)CHACAMAN Wrote: hi, thans for time and help, guys i have a 4AGTE whit the next setup: Assume you mean springs, and retainers??? You will still have to check valve clearances, and possibly change shims - No cam will say they don't need to check valve clearances. ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
Camshaft ID | kazi | 6 | 8,846 |
09-26-2018 12:07 AM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 18,375 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Camshaft sprocket bolt size? | harkes | 1 | 5,413 |
Camshaft questions | d3nso | 7 | 9,130 |
08-16-2013 11:19 PM Last Post: jondee86 |
What camshaft | Anonymous | 9 | 10,824 |
09-01-2010 10:51 PM Last Post: banpei |
