Question about 4AG 20v Engine Block
06-10-2022, 05:17 PM
RE: Question about 4AG 20v Engine Block
(05-29-2022 02:38 PM)CHACAMAN Wrote:  Hello guys, thanks for your time and help, I have the following question: I broke my 4AGZE engine due to bad luck and I can no longer find the 4AGZE 3rd generation engine block, I can only find the 4AGE 20v Engine block, my question is can I use this block by placing the pistons and the crankshafts from my 4AGZE on the 20v block crankshaft and get 300-320WHP without modifying the block? I mean without having to change the sleeve?
Thanks
You should have no issues with using a 20V block.... other then you will also need a 20V oil pan... OR the MRP oil pan (recommend).
300+hp is attainable with the appropriate boost level and tune.
Dan -
Messages In This Thread
RE: Question about 4AG 20v Engine Block - oldeskewltoy - 06-10-2022 05:17 PM
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 15,828 04-19-2021 10:08 PM
Last Post: Hanzo
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 17,824 02-10-2020 06:39 PM
Last Post: Power_uP
  4AGE block differences explained (incl. some eyecandy) Bean 46 106,198 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 9,997 02-06-2018 06:27 PM
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 7,212 11-05-2016 01:34 AM
