Propeller shaft universal joint
05-19-2014, 06:03 AM
The universal joint on the propeller shaft(near the diff) is loose and making noise, how do we replace it?
I am told that this is not replaceable and have to replace the whole shaft+joint.
05-19-2014, 11:05 AM
Just take it to shaft service, mostly they do trucks, but will fix that up no problems.
  STL file for the early spec Levin headlight ball joint plastic clip DaLanZhu 2 1,945 04-26-2025 03:24 PM
Last Post: DaLanZhu
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 9,489 07-31-2019 11:28 AM
  Steering shaft issue Ryo 15 16,765 11-19-2018 09:52 AM
  Original gauge with universal fuel sender Komba 4 7,975 01-05-2015 03:27 PM
Last Post: Komba
  Play in prop shaft (diff end) phill 92 14 18,249 08-07-2012 02:13 PM
Last Post: phill 92
